Inside air temperature will not change
Old Nov 11, 2004 | 01:50 PM
31flavorscivic's Avatar
Default Inside air temperature will not change
I've tried searching, maybe I'm just not good at it...
91 civic SI. My climate control only puts out hot air. The **** is hooked up and everything, I have the analog ****. The fan works and everything. Is this problem electrical in nature, or is there something broken/not hooked up from the **** to whaveter regulates the temperature. Could it be the thing that regulates the temperature, and if so what is it? This isn't a problem now because its extremely cold, but I wanna get a head start before nex summer lol.
Old Nov 11, 2004 | 01:53 PM
crx_88_si's Avatar
go look in the engine bay, below your fuel filter. have some1 turn the **** inside the car. you should see a little cable that moves a valve. if it's off the valve is stuck to "let hot coolant in".
Old Nov 12, 2004 | 09:35 PM
Default Re: (crx_88_si)
thanks for the advice,
I found the thing, and basically the arm was backwards, so cold was open and hot was even MORE open, so basically it was just hot. A quick adjustment fixed the problem. HUGE HELP!! thanks!
Fo-Do Fanatic
Nov 21, 2009 09:42 AM
crxtuner69
Oct 16, 2005 07:28 AM
Pee Wee
Jul 9, 2004 09:59 PM
wblakes
Jun 6, 2004 11:18 AM
Cosworth
May 10, 2002 10:04 AM
