SI supsension VS. Civic Supsension
Old Nov 11, 2004 | 01:35 PM
Dly989's Avatar
Default 99-00 SI supsension VS. 97 Civic DX/LX/EX Supsension
hey I was wondering if the SI OEM supsension are lower than the Civic EX/ DX/ and LX models. I have a DX, and Im kinda broke, and I want to lower my car, but only an inch, and I dont want to spend alot of money on aftermarket supsension. If the SI supsension is lower than an EX/DX/LX, I was wondering by how much. Thanks
Modified by Shikaruto at 2:46 PM 11/11/2004
Old Nov 11, 2004 | 01:53 PM
Frozen E's Avatar
H-T White Ops
if you're kinda broke just chop your springs.
Honestly, the Si springs are probably a higher spring rate than what you have right now. Also, more than likely they're going to ride higher than what your stockers are at right now. So higher AND rougher ride. You get the worst of both worlds.
Old Nov 11, 2004 | 01:59 PM
SOHC4life 96's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">if you're kinda broke just chop your springs.
Honestly, the Si springs are probably a higher spring rate than what you have right now. Also, more than likely they're going to ride higher than what your stockers are at right now. So higher AND rougher ride. You get the worst of both worlds. </TD></TR></TABLE>
Yeah, just save up some money and buy some eibach prokit springs.
Old Nov 11, 2004 | 03:26 PM
Dstretch33's Avatar
Default Re: (DOHC4life)
No, the si suspension is not lower. The factory height is like a truck, like most other hondas. OOOhhhh and please dont cut your springs, that is the worst thing to do. You might get lucky had have similar spring rates when done, but most likely u will be bouncy all over the place. Just save up and get some springs there around or under $200.
Smackin
Dec 7, 2018 11:59 AM
redvtec00
Suspension & Brakes
Feb 23, 2006 08:49 PM
redvtec00
10
Feb 23, 2006 03:41 AM
eg ferio
Dec 5, 2003 05:47 AM
Blackrain
Feb 24, 2003 01:10 PM
