cluster question
Old Nov 11, 2004 | 01:08 PM
DaKINE-Ek's Avatar
From: So Cal where old pople try to race you, U.S.A
Default cluster question
how do disconnect the wires out of the connectors behind the cluster for the B and the C connectors.
Old Nov 11, 2004 | 01:18 PM
DaKINE-Ek's Avatar
Default Re: cluster question (DaKINE-Ek)
bump i need to kno!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 11, 2004 | 01:32 PM
DaKINE-Ek's Avatar
THE WIRES WONT COME OUT HHHHEEEEEELLLLLLLPPPPPPP!!!!!!
Old Nov 11, 2004 | 01:37 PM
BlueIntegraBoy's Avatar
There's the white plastic things that prevent the wires from coming out. You're gonna need a safety pin or paper clip. You need to release that white plastic piece by pushing in on the sides and the middle. It will slide out. Now, take your safety pin and from the front, push in the small hook thing and pull the wire. The plastic hook thing needs to be pushed down to unclip the wire. I hope this is a good enough explanation.
Modified by BlueIntegraBoy at 12:48 PM 11/11/2004
Old Nov 11, 2004 | 02:01 PM
DaKINE-Ek's Avatar
Default Re: cluster question (BlueIntegraBoy)
thanks for the help.
Old Nov 11, 2004 | 02:46 PM
DaKINE-Ek's Avatar
ok i got the white clips out and what do i do with the wires. they still wont come out.
Old Nov 11, 2004 | 02:53 PM
From the front of the clip (the squarish hole). Use a safety pin and push down on the small plastic hook to unclip the wire. Once you push down the hook, pull on the wire and it slides out.
Old Nov 11, 2004 | 02:56 PM
DaKINE-Ek's Avatar
the whole metal casing comes with it?
Old Nov 11, 2004 | 02:57 PM
yes
Old Nov 11, 2004 | 03:51 PM
DaKINE-Ek's Avatar
ok. i used this write up https://honda-tech.com/zerothread?id=474760 and merrit.com. and i still go owned. im a wiring n00b i guess. when i turn my head lights on my tach goes form 1k to 0 and my speedo doesnt work. the cruise control light and abs light is on. and my blinkers are all criscrossed and my high beam light on the cluster is not working.
Old Nov 11, 2004 | 04:14 PM
DaKINE-Ek's Avatar
bump for this.
Old Nov 11, 2004 | 04:32 PM
Do you have the depinning all down? When I swapped an LS cluster into my friend's 00 EX, I used this guide... http://www.geocities.com/_nitr....html
I repinned my plugs and had no problems at all. It tells you what to do for the SRS plug.
D95si420
Nov 8, 2007 10:10 PM
REDBARON
Sep 24, 2006 07:08 PM
slpr_civic93
May 27, 2006 07:59 PM
DCivic00
Nov 18, 2004 05:48 AM
GroundZer0
10
Apr 11, 2003 08:02 AM
