Honda S2000 Honda S2000
Picsof S2000 Sheet Metal Intake Manifold -- not commercial, because we arent selling any
Old Nov 11, 2004 | 12:18 PM
Full-Race Geoff's Avatar
Default Picsof S2000 Sheet Metal Intake Manifold -- not commercial, because we arent selling any
here are some pics of a fabricated manifold we recently did for a customer. It still uses the stock honda IAC system (99.99% of others dont do this) it still uses a stock honda IAT sensor, and it still uses a stock honda TB and tps.
we hand fabricated the plenum, and the runners are CNC machined from solid billet aluminum. The fuel rail is machined to accept 1008cc/min injectors.
Old Nov 11, 2004 | 12:25 PM
WowOzYouRock's Avatar
Default Re: Picsof S2000 Sheet Metal Intake Manifold -- not commercial, because we arent selling any (Full-R
can you make me one ? pm me how much ....
btw , i likey alot ....
Old Nov 11, 2004 | 12:43 PM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">can you make me one ? pm me how much ....
i also agree that it looks good....
however, does it make any power.... dyno plots or flow chart?
Old Nov 11, 2004 | 01:00 PM
poop32145432's Avatar
Looks like an ITB with a cover over it. But other then that, it looks hella badass. But as posted earlier and most importantly, does it have any gains?
Old Nov 11, 2004 | 01:34 PM
blues2k3's Avatar
Geoff,
I told Todd I will send you the Intake Manifold after we begin to dismantle the car in about two weeks...Thanks again for everything
Arnold
Old Nov 11, 2004 | 02:38 PM
skafia's Avatar
25 Year Member
The welds are sooo ugly.
Old Nov 11, 2004 | 03:08 PM
it will make big power on big turbo cars. no flow charts, no dyno charts. If someone wants one, they are 1900, but we may not make more, simply becuase they are so time consuming.
Old Nov 11, 2004 | 03:20 PM
Mase's Avatar
damn thats hot, and that had to take forever to make
Old Nov 11, 2004 | 03:40 PM
The Original Whitey's Avatar
looks nice, do you just sell CNC runners and if so how much?
Old Nov 11, 2004 | 03:47 PM
Default Re: (Whitey.)
We do sell the runners, they are $119 each. Engineered to true ASME spec, and include a weld seat.
Old Nov 11, 2004 | 04:59 PM
Project SSAP1's Avatar
that sir def looks pimp
Old Nov 11, 2004 | 08:01 PM
nightrider's Avatar
those are definitely high quality welds and it seems you guys took your design into progress. dyno charts would be badass.
Old Nov 11, 2004 | 08:28 PM
Mr. Projekt's Avatar
* B A N N E D *
very nice. i like the inside view of the horns.
Old Nov 12, 2004 | 06:34 AM
cjb80's Avatar
Unfortunatly I won't be able to provide accurate dyno numbers as I am making a complete overhaul of the entire car at once. I am installing a new motor, new turbo, manifold, intake manifold, plumbing, injectors, fuel system and exhaust system all at once. I should have the car running towards the beginning of December. I am shooting for 750 rear wheel or so... after I complete this mission I am gonna try and sell it in case you guys know anyone who wants the past and future most power s2000 evar
Chris
Old Nov 14, 2004 | 12:01 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">The welds are sooo ugly.</TD></TR></TABLE>
have you ever welded alum? It's not so easy and the welding seam is typically large compared to welding steel with a tig.
the manifold looks like it has good craftsmanship. One question, while the runners are offset in the plenum, they seem shorter than stock?
Is the plenum volume larger than stock?
The manifold flange is missing the secondary air injection valve assembly, so this manifold is obviously for cars that wont see the streets or with ones missing the secondary air injection system? No clearance problems with air temp sensor hitting the hood or has then angle of the runners been altered to provide more manifold to hood clearance?
While it's hard to avoid a tech thread turning commerical, I aplaud your guys effort to do something different and it's very cool to see new stuff out that's done nicely! I can't wait to get my car on the dyno to see the effects of the carbon manifold.
Old Nov 15, 2004 | 08:23 AM
the runners are slightly different than stock. larger diamaeter and slightly shorter (not as short as you may think)
the plenum volume is VERY healthy for a motor of this size, and yes it is missing the secondary air injection valve. this has been welded shut and then resurfaced.
glad you like the manifold. which manifold do you have, you mentioned carbon so i assume it is AIR??
Old Nov 15, 2004 | 08:28 AM
CLOUT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjb80 &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunatly I won't be able to provide accurate dyno numbers as I am making a complete overhaul of the entire car at once. I am installing a new motor, new turbo, manifold, intake manifold, plumbing, injectors, fuel system and exhaust system all at once. I should have the car running towards the beginning of December. I am shooting for 750 rear wheel or so... after I complete this mission I am gonna try and sell it in case you guys know anyone who wants the past and future most power s2000 evar
Chris
to geoff, and i can't wait to see chris' s2
Old Nov 15, 2004 | 11:34 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">the runners are slightly different than stock. larger diamaeter and slightly shorter (not as short as you may think)
glad you like the manifold. which manifold do you have, you mentioned carbon so i assume it is AIR??</TD></TR></TABLE>
Shoot me a PM, I don't want to change subjects on your thread, it's not the AIR manifold
Old Nov 15, 2004 | 12:33 PM
Raymund's Avatar
New User
Beautiful craftmanship
Also, curious of the volume of the manifold compared to stock. Is it possible to go bigger without running into clearance problems?
Old Nov 15, 2004 | 12:37 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Raymund &raquo;</TD></TR><TR><TD CLASS="quote">Beautiful craftmanship
Also, curious of the volume of the manifold compared to stock. Is it possible to go bigger without running into clearance problems?</TD></TR></TABLE>
it's a tight fit in there, but there is room for something bigger than stock
Old Nov 15, 2004 | 02:25 PM
volume is HUGE compared to stock.
Old Nov 17, 2004 | 07:25 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Looks pretty hardcore.
Old Nov 17, 2004 | 07:30 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">damn thats hot, and that had to take forever to make </TD></TR></TABLE>
pro-jay
Honda S2000
24
Dec 5, 2016 10:42 AM
GDM Ap1
Honda S2000
Feb 23, 2006 02:23 PM
HotWheelz
Honda S2000
Oct 28, 2002 01:48 PM
prospeed
Mar 8, 2002 10:02 PM
