Sohc Compression Test Results
Old Nov 11, 2004 | 12:17 PM
Negative3Five's Avatar
Default Sohc Compression Test Results
Hey I just did a compression test on my 97 HX motor with 90K miles and the results came out kinda low to what I found on here: #1 100 #2 95 #105 #90 Thier is no blow by coming out the exhaust and the plugs looked to be kinda grey indicating they were lean but that shouldn't of effected the compression. Do you think my motor is gone? And would needing a oil change effected my results It's low by a quart at least.
Old Nov 12, 2004 | 09:14 AM
93b20z's Avatar
Default Re: Sohc Compression Test Results (Negative3Five)
how do you do a compression test?
Old Nov 12, 2004 | 09:17 AM
nighttrain33's Avatar
Default Re: Sohc Compression Test Results (hmongyaj7)
If you buy a Hayne's, it tells you how to do just about ANYTHING. You have to buy a compression tester to do this. And needing an oil change shouldn't have anything to do with compression. But I definitely wouldn't drive around on 3 quarts of oil either.
-Shane
BauleyCivic's Avatar
Risky Business
Thats weird...all the numbers are consistent, but really low...most sohc's are supposed to be 180-200...
BUT...the HX only uses 1 intake valve until 2500...so that might have something to do with it. As long as the motor runs fine and you're not burning oil or coolant I wouldn't worry about it.
Old Nov 12, 2004 | 09:22 AM
Yea i'm not burning oil or coolant I'm gonna do a leak down test tuesday...O about the oil change I just havn't had time to do it cause of school im gonna do it tom. when I wake up.
Mr_ET
Jul 31, 2007 01:07 PM
JDMtype Eg6
Jul 14, 2007 02:31 AM
Azcheron
Jun 23, 2005 09:34 PM
blackeg
Mar 28, 2005 06:10 AM
Trellis
Sep 29, 2004 07:41 PM
