Help with Power windows..
I have the power wndow..mirrow..locks....the thing is that...i plug everything in...and only the power lock and power mirror works..any reason why my window won't roll down or up...on both driver and passenger side???help needed..
Stupid question, did you check the fuses for the windows, also check the clip that plugs ino the harness on the driver door, sometimes that may come loose and either blow a fuse or just disconnect.
why is it a stupid question??? can't be stupid if your fuses are not burnt and the plugs are in...I need help..not someone who say it's stupid...have you ever heard of there is no such thing as a stupid question??
I am currently installing power windows on my car too. What year is your car and what trim line is it? Did you install the power window relay? If you don't have it, the power will not we routed to the power windows. You also have to make sure that you ran the power wires from the under-dash harness to the doors.
the year of my car is a 92 civic CX hatchback...power window relay?? i have no clue what that would be...and what do you mean by trim line???well i do have the wire that plugs into thepassenger side door...and also the driver side door...could you please tell me where the power window relay would lay..is it on the fuse box itself or it's a seperate thing...
urkuletz
Honda Civic (2001 - 2005)
Dec 14, 2007 05:47 AM
