engine knocking
Old Nov 11, 2004 | 11:23 AM
oxygen241's Avatar
Default engine knocking
i have a 1994 honda civic si hatchback vtec 1.6L and and when i rev my engine or am accelerating there is a tickin sound it doesnt make it when idleing just when engine is being reved or when accelerating the noise seems to be coming from the front of the engine
can anyone help me to figure out whats wrong
Old Nov 11, 2004 | 11:26 AM
nighttrain33's Avatar
Default Re: engine knocking (oxygen241)
Just like the last thread that you posted in, he said the same thing. But we need to know if it is a "ticking" from the head or a "knocking" from the block. If it is from the head than it is probably a valve problem. If it is from the block it just may be a bearing.
-Shane
Old Nov 11, 2004 | 11:36 AM
oxygen241's Avatar
Default Re: engine knocking (nighttrain33)
its coming from the front of the block and i did over rev and it didnt do that before i over reved
Old Nov 11, 2004 | 11:43 AM
Well, if it's coming from the block, then like I said, it might be a spun bearing. Let's get some more posts to back this up though! Good luck.
-Shane
Old Nov 11, 2004 | 12:06 PM
jbs's Avatar
jbs
I agree! You'v got rod knock. The knocking sound will get worst until it makes a hole in the block.
Old Nov 11, 2004 | 12:14 PM
backdraft's Avatar
I agree..... One of my friends had the same thing. It just kept getting worse. You can look in the vtec solenoid and see if there are metal shavings in there. If there are it is a spun bearing. Unless it just started then it might not be up there yet. But every time that I have had to fix this problem there are metal shavings in the solenoid.
Old Nov 11, 2004 | 01:00 PM
oxygen241's Avatar
Default Re: engine knocking (backdraft)
where is the vtec solenoid located
Old Nov 12, 2004 | 11:55 AM
oxygen241's Avatar
do you know if i have to pull out my engine to fix this problem
Old Nov 12, 2004 | 11:58 AM
hondaeg8's Avatar
drop your oil pan and see what you find
Old Nov 12, 2004 | 12:07 PM
If you are looking at the front of the car, the vtec solenoid is on the left side of the motor, almost right below the distributor. If you get a Hayne's, it will help you out considerably with this. It is hard to tell you exactly where it is.
-Shane
Old Nov 12, 2004 | 12:15 PM
colinproctor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">Just like the last thread that you posted in, he said the same thing. But we need to know if it is a "ticking" from the head or a "knocking" from the block. If it is from the head than it is probably a valve problem. If it is from the block it just may be a bearing.</TD></TR></TABLE>
thats what i am saying "knocking" or "ticking". what the hell, get it straight, they are totaly different things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">Well, if it's coming from the block, then like I said, it might be a spun bearing. Let's get some more posts to back this up though! Good luck.</TD></TR></TABLE>
good advise. if it is "knocking" that would be my guess.
Casper NL
Dec 30, 2012 08:13 AM
gs R eg6
Mar 19, 2009 01:54 PM
islowteg
May 8, 2007 03:43 AM
klipstang
Dec 27, 2005 11:40 AM
ranta18
Aug 7, 2005 05:20 PM
