JDM sidemarkers
Old Nov 11, 2004 | 10:36 AM
chill00lude's Avatar
Default JDM sidemarkers
hey does anyone have any experience installing the jdm sidemarkers, just wondering what exactly you have to do for installation
Old Nov 18, 2004 | 05:28 AM
kickinchicken's Avatar
Default Re: JDM sidemarkers (chill00lude)
http://store.yahoo.com/autosonic/19prb.html
this should help.
Old Nov 19, 2004 | 04:55 AM
shad's Avatar
Default Re: JDM sidemarkers (h23sleeper)
I basically used a peice of masking tape measured from the center of the corner markers.
Then measured from the bottom of the fender made sure both sides were even.
Then put 3 peices of masking tape from the fender seam it was about 3 fingers in size.
Leave the tape on.
I then measured the jdm fender marker light and marked where I needed to make my cut with my dremel.
Start with small cuts first because if you get too big you are screwed and have to get another fender.
Cut until you can get the sidemaker in and out.
Then clean up the burrs with a dremel sanding wheel paint the bear metal areas with touch up paint.
Wire your lights install them and you are done.
Mine came out pretty good for a first time doing it.
I wired them to the lower side turn signals they come on when the parking lights are on and also blink as well.
You can just wire them to the front signals too.
This way they just blink when the turn signal is on.
I used superwhite bulbs in the side markers it's your choice though whatever looks better on your ride.
Goodluck
Old Nov 19, 2004 | 08:41 AM
hey thanks alot
Old Nov 19, 2004 | 02:35 PM
ph8ed4life's Avatar
Default Re: (chill00lude)
Heres the link to my thread on this, lots of good measurements and info
https://honda-tech.com/zerothread?id=1024325
feel free to post in it, daniel(RHD_BB4T) is an awesome dude and quite damn helpful
Old Nov 20, 2004 | 01:20 PM
iCe_2x's Avatar
Default Re: JDM sidemarkers (shad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shad &raquo;</TD></TR><TR><TD CLASS="quote">I basically used a peice of masking tape measured from the center of the corner markers.
Leave the tape on.
Goodluck
you wired them to the parking lights? but then, that way, they wont blink unless parking lights are on, right? cuz when your parking lights are off the our peices on the bumper dont blink..
Old Nov 24, 2004 | 06:20 AM
shad's Avatar
Default Re: JDM sidemarkers (iCe_2x)
No they still blink.
I wired them to the side front bumper light turn signals. They come on when the parking lights are on and still blink when the signal is on.
Go turn on your lights and look at the front turn signal the side lights will be on.
Then turn off the parking lights and turn on your turn signals the side turn signal will blink. If yours doesn't blink I don't know what to tell you. Mine blink at different rate.
Modified by shad at 10:37 AM 11/24/2004
Old Nov 24, 2004 | 08:54 AM
OTT's Avatar
OTT
I have a JDM 4g and they dont have sidemarkers like that wired as standard, although there is a connector on each side that isnt used and is taped on the same wires as the front facing indicators.
Old Nov 24, 2004 | 02:16 PM
mgags7's Avatar
Default Re: (OTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT &raquo;</TD></TR><TR><TD CLASS="quote">I have a JDM 4g and they dont have sidemarkers like that wired as standard, although there is a connector on each side that isnt used and is taped on the same wires as the front facing indicators.</TD></TR></TABLE>
you probably dont have foglights right?? if not, then those are the connectors for em....if you do, maybe the jdm ones all cam w/connectors even though you dont have markers...
Old Nov 24, 2004 | 04:53 PM
tdo's Avatar
tdo
This is how I did mines..... measure it then use a piece of cardboard and cut out a perfect hole for the side markers. Then tape it to your car where you did the measurements. Then use a dremmel and cut out the hole ( make sure you cover up the area around so you dont accidently scratch your paint)
BTW USE GOGGLES.
Old Nov 25, 2004 | 09:39 AM
OTT's Avatar
OTT
Default Re: (mgags7)
I have fender/wing sidemarkers but The 'dormant' reflectors do not light up.
I dont think the wires on the are long enough to reach where fogs would go but I do have a set of raybrigg foglights seperatly wired.
WTDRs down for now but Ill putup a couple of pictures in a while and one showing with the front bumper removed so you can identify the wires Im talking about
Old Nov 25, 2004 | 10:22 AM
ef93si's Avatar
how much do you think a body shop would charge to cut those holes out?
i dont trust my straight line drawing abilities
Old Nov 25, 2004 | 01:37 PM
tdo's Avatar
tdo
Default Re: (ef93si)
do it yourself and save money because I have 2 friends that took theirs to a shop and they fucked it up. The holes are too big.... so DIY !! take your time.
Old Dec 6, 2004 | 10:40 PM
Weapon's Avatar
Got a pair of prelude sidemarkers if anyone is interested
PM me
Old Dec 7, 2004 | 12:28 AM
wstef's Avatar
In JDM/european OEM solution they are NOT sidemarkers, and are NOT turned on with parking lights.
They are turn indicators and blink exactly like rear turn indicators in taillights
ThatRHDstatus
Mar 25, 2010 01:45 PM
HFP-EP3
Dec 24, 2007 02:16 PM
mani_0130
Dec 14, 2007 08:37 AM
Tyle R_BB6_Boi
Jun 5, 2007 05:31 PM
GraphiteMW
Mar 19, 2007 12:45 AM
