Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Suspension Techniques front sway bar on ITR
Old Nov 11, 2004 | 07:00 AM
00R101's Avatar
Default Suspension Techniques front sway bar on ITR
First off, let me say that I have used search and although there are many posts on the topic, none of them answer my questions.
I have a 1" ST front sway bar (marked "for Integra and Civic"). It has the end-link mounting points approx 90 degrees from the ITR placement. If I wanted to use this bar on my ITR, could I purchase the non-ITR end-links from Acura and successfully install it?
Is there an ITR specific ST bar?
Has anyone done this?
Old Nov 11, 2004 | 07:11 AM
JeffS's Avatar
Default Re: Suspension Techniques front sway bar on ITR (00R101)
Yes, the mounting point on the LCA is the same for all the integras.
You might want to look at someone like Energy Suspension for the links. They're only like $13.
Old Nov 12, 2004 | 05:50 AM
typer_801's Avatar
Send Fitzpatrick a note...I believe he had one of those installed on his ITR earlier in the year.
Old Nov 12, 2004 | 08:49 AM
bfitz's Avatar
Default Re: Suspension Techniques front sway bar on ITR (typer_801)
Yes, I did. The bar came with end-links that worked with the ITR (and non-ITR). I ditched it for a JDM ITR bar for the better end-links and to get rid of the huge aluminum spacers that the ST bar requires.
Anyone want a 1" ST bar???
Old Nov 15, 2004 | 05:10 AM
00R101's Avatar
Default Re: Suspension Techniques front sway bar on ITR (bfitz)
So after installing the bar and running a very tight very bumpy event on street tires at about 45 degrees, I have the following observations:
Turn in seems slightly better but turn in understeer can be induced more easily. Once the thing is understeering it takes lots more effort to neutralize. Seems to be able to lay down more power on corner exit. Can't really test until I get on R tires and have a reasonably flat lot.
Brian, care to divulge your secrets for taming the increased underseer?
-alan
Old Nov 15, 2004 | 07:03 AM
stevel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00R101 &raquo;</TD></TR><TR><TD CLASS="quote">care to divulge your secrets for taming the increased underseer?
-alan</TD></TR></TABLE>
bigger adjustable rear bar
s
Old Nov 15, 2004 | 07:09 AM
.RJ's Avatar
.RJ
Default Re: Suspension Techniques front sway bar on ITR (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">bigger adjustable rear bar
s</TD></TR></TABLE>
Not legal for D-Stock....
I ran on track for a session w/ a 26mm rear bar on my ITR (stock suspension except Konis) and I'm dont think that a big rear bar by itself is really the answer.
Old Nov 15, 2004 | 08:57 AM
bfitz's Avatar
This one took me a while, but I was too stubborn to put the stock bar back on, because I really believe that the bigger bar should be faster.
I tried upping the rear tire pressures until I was outside the range of my gauge (65+ psi), but that didn't help. So, I went the other way. I ended up running 48F/30R at Nationals on A3S04's. Of course, that may not work the same on different tires.
Old Nov 15, 2004 | 09:19 AM
solo-x's Avatar
brian, did you try running with any rear toe-out?
nate
Old Nov 15, 2004 | 05:39 PM
bfitz's Avatar
Default Re: Suspension Techniques front sway bar on ITR (solo-x)
I ran the rear at around 1/8" total toe-out all year. In my limited experience, too much toe-out is difficult to drive. With low tire pressure, the rear end is very predictable.
Brian
FearSC549
Suspension & Brakes
Aug 14, 2012 09:41 AM
nw dc two
Jan 7, 2007 11:01 AM
fastfu
Jun 8, 2004 04:02 AM
fuguman
Sep 30, 2002 11:29 AM
nuspeed27
Sep 18, 2002 11:01 AM
