ohms Resistance
Old Nov 10, 2004 | 09:09 PM
CalMatrix's Avatar
Default ohms Resistance
How do you measure the ohms resistance on a fuel level sending unit to determine the correct fuel gauge, or does someone know the numbers? (92 Prelude)
Old Nov 11, 2004 | 01:27 AM
pentaq's Avatar
Default Re: ohms Resistance (CalMatrix)
You don't check the resistance but voltage. Check the voltage between YEL/GRN and body ground after turning ignition on. It should read 5-8V if not check wires or the gauge.
Old Nov 11, 2004 | 11:21 AM
CalMatrix's Avatar
Default Re: ohms Resistance (pentaq)
I am trying to determine which AutoMeter electric fuel gauge to buy for a 92 Prelude and the measurements are "ohm full and ohm empty". Here is the web site:
http://www.egauges.com/vdo_mul...Cart=
fusedfish12
Aug 2, 2013 01:28 PM
TAZ95
Feb 13, 2011 11:51 AM
CalMatrix
Nov 10, 2004 09:23 PM
