OBD0 automatic integra ecu?
Old Nov 10, 2004 | 08:50 PM
xci_ed6's Avatar
Default OBD0 automatic integra ecu?
Is that a PR4, or something else?
I need one for the mini-me project i'm working on. I want a higher rev limit, and me 4d is an auto.
-Dustin
Old Nov 11, 2004 | 05:01 AM
turboimports's Avatar
Default Re: OBD0 automatic integra ecu? (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">Is that a PR4, or something else?
-Dustin</TD></TR></TABLE>
Yes PR4 would be the 90-93 integra ECU.
If you are doing a mini-me with a d16z6...you will have to go to obd1
if d16y8..obd2
unless you can rewire everything to accept obd0 and use a jdm obd0 B16A1 ecu.
-Lor
Old Nov 11, 2004 | 05:14 AM
crxgator's Avatar
either that or a PG7 from a 88-89 teg...
Old Nov 11, 2004 | 07:54 AM
xci_ed6's Avatar
Default Re: OBD0 automatic integra ecu? (crxgator)
thanks gator
I've got an E-manage to trim the fuel maps and switch VTEC. I just needed something with a higher rev limit that still has a lockup solenoid output, and preferably plugs in.
edit: letme make sure you answered the question i asked, i dont know if i was clear, PG7 = OBD0 w/ auto trans?
Old Nov 11, 2004 | 08:05 AM
crxgator's Avatar
well pg7 is 86-89 integra...you have to find a 88-89 and one that is automatic for it to work correctly...i dont know the exact model number off hand, but pgmfi.org will probably have it listed though...
one thing im not sure of though is if you will get an exhaust cam angle sensor CEL...best bet is to ask on the pgmfi forum...
i think the pr4 has a 7000 fuel cut off? and pg7 is 7500... again ask on pgmfi to be 100% certain...
gulftiresinc
Apr 27, 2007 06:30 AM
davidcrx89
Feb 10, 2007 02:16 PM
D Grade
12
Sep 10, 2005 07:00 PM
90civichbsi
20
Oct 8, 2002 10:51 PM
