installing ARP rod bolts
Old Nov 10, 2004 | 08:30 PM
boosted k20's Avatar
Default installing ARP rod bolts
okay i just read that u need to take ur rod to a machine shop in order for them to press in the new arp rod bolts. is this true?
how do they install the bolts? has anyone of u installed tehm w/o go n to a machine shop. if so how did u do it
Old Nov 11, 2004 | 09:24 AM
Default Re: installing ARP rod bolts (boosted k20)
anyone?
Old Nov 11, 2004 | 11:37 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
take then to the machine shop, they rods would need to be trued after the install.
stan
Old Nov 11, 2004 | 12:04 PM
hype r 555's Avatar
Default Re: installing ARP rod bolts (Stan D)
you can size the rods your self if you want , but you will need to know the stretch specs for the bolts and poss. a tap set , ... you do not need to have a machine shop press them in , because there is no pressing needed but keep in mind if they are not strtched correctly you will have beairng , prob.... i guess in a nut shell if you have installed oem rod. bolts you can do it yourself , if you have never done rod bolts , have yuor local tuner do it ....
EGRhatch
Feb 5, 2013 08:49 AM
zangiefisgod
Feb 28, 2006 05:46 PM
boostd ls
Jan 17, 2006 02:46 PM
turbohf
May 11, 2004 06:30 AM
dsadas89das78934
Nov 7, 2003 11:59 PM
