88 CRX DX, CEL Throwing Code 1
Old Nov 10, 2004 | 08:22 PM
crxforum's Avatar
Default 88 CRX DX, CEL Throwing Code 1
Ok I just started a new job. Yesterday afternoon I went in for the interview and on the way in my CEL came on. The car seemed to loose power a bit. Maybe not loose power as much as rev higher before shifting. I drive an auto. Anyways I thought that it might just be because I have only driven it about 2 hours in the last week and it was being stupid. But then after the interview I had to head out and visit my mom and the CEL came on again on the way there, and then again on the way home.
On my way in for my first day of work today the CEL came on again. This time I was going slower becuase I thought that it had something to do with speed. Since it was coming on before at about 100kmph. But this morning on the way in it came on at about 70kmph so that theory was shot to ****.
I cant seem to find my guide on what the codes mean, and Im really busy to go and search around for what Code 1 means. Anyone have any idea of what the problem might be. That yellow light coming on again pretty much makes me flash to an image of an empty wallet on an engine that sucks ***** anyways.
I did the math at lunch today and in the last year if I would of just dealt with the problems instead of replaceing the parts for my engine I would of saved enough money to buy a full DOHC ZC swap with tranny, ECU and everything I needed.
CRX Forum
Old Nov 10, 2004 | 09:08 PM
eda6's Avatar
Default Re: 88 CRX DX, CEL Throwing Code 1 (crxforum)
code 1 oxygen content
Old Nov 10, 2004 | 09:10 PM
crxforum's Avatar
Default Re: 88 CRX DX, CEL Throwing Code 1 (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">code 1 oxygen content</TD></TR></TABLE>
**** are you serious? I just replaced my O2 Sensor like 3 months ago. Can you think of a reason why this might be happening? I cant think of anything.
CRX Forum
Old Nov 10, 2004 | 09:15 PM
eda6's Avatar
If you just replaced it then i'd check the wiring. If that checks out, test the o2 sensor. What o2 sensor do you have?
Old Nov 11, 2004 | 09:05 AM
crxforum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">If you just replaced it then i'd check the wiring. If that checks out, test the o2 sensor. What o2 sensor do you have?</TD></TR></TABLE>
Do you know how to test the sensor? I checked the wiring and cant seem to find anything wrong. Everything seems to be connected correctly, there is no grounding out going on. I have no idea what O2 sensor that I have.
CRX Forum
Old Nov 11, 2004 | 03:18 PM
eda6's Avatar
Check your fuel pressure. Make sure the fpr is good.
Disconnect the wire harness from the o2 sensor. See if you have .6V during wide open acceleration and .4V during closed throttle deceleration from 5000 rpm. If no o2 sensor is bad.
If the you have the correct voltage do the above test again, check voltages at the ecu. c16 (+) and a18 (-). If you have 0V there's an open/short somewhere in the circuit. If you have the correct voltage get another ECU.
crxowner
Oct 12, 2011 02:54 PM
dmeconitas
Jul 17, 2009 05:54 PM
h22bb1
May 22, 2008 09:25 PM
CapnChunk
Mar 23, 2003 07:33 AM
