Idle surge
Old Nov 10, 2004 | 07:18 PM
x00gsr's Avatar
Default Idle surge
Okay, I've done searched already and Still can't figure the problem. Well, when I'm at a complete stop it doesn't surge, but when i'm rolling and throw it into neutral it rolls back to 1000 and surges to 1500 rpms. What is causing it to do this? Bad TPS sensor maybe?
Old Nov 10, 2004 | 07:36 PM
thisisntjared's Avatar
Default Re: Idle surge (x00gsr)
i have a similar problem but im throwing code 14. does it idle normal but if the rpms are between 1-2 rpm then it surges?
Old Nov 10, 2004 | 08:24 PM
Phantastic's Avatar
i had that problem and it was my iac sensor. it's that sensor in back of the intake manifold. change that u should be good
Old Nov 10, 2004 | 08:36 PM
Sh4d's Avatar
idle air control valve. either has gone bad, screen has been clogged, or you opened the cooling system and didn't bleed it after.
Old Nov 10, 2004 | 08:53 PM
DJ_SaNdOz's Avatar
http://www.ef-honda.com/ben/Badidle.html
Nick Chambers
Sep 10, 2017 03:29 PM
5thGeneration
Jan 3, 2008 01:49 PM
Laz's EP
Nov 20, 2007 08:22 AM
rdeezy25
May 17, 2005 01:55 PM
ek_b16
11
Mar 4, 2005 08:15 PM
