I can't use my heat! PLEASE HELP!
Old Nov 10, 2004 | 06:55 PM
Hesh's Avatar
Default I can't use my heat! PLEASE HELP!
the switch that changes the air from hot to cold on the dash of my '98 Integra apparently disconnected from whatever it moves to control the temp of the air. The switch was stuck, and as I was moving it, it seemed to have popped out.
PLEASE HELP! IT'S COLD!!!
Modified by Hesh at 6:00 AM 11/11/2004
Old Nov 10, 2004 | 07:37 PM
honda011's Avatar
Default Re: I can't use my heat! PLEASE HELP! (Hesh)
wrong forum this is the integra forum...
Old Nov 11, 2004 | 04:29 AM
JimBlake's Avatar
Maybe only the **** broke? Happened to our '98, that seems to be the weak spot, & it's easy to replace.
Old Nov 11, 2004 | 05:01 AM
Hesh's Avatar
Default Re: I can't use my heat! PLEASE HELP! (honda011)
I do have an Integra, I accidently wrote Accord because that was my old car. Sorry!
Old Nov 11, 2004 | 05:12 AM
Hesh's Avatar
Default Re: I can't use my heat! PLEASE HELP! (JimBlake)
How much did the **** cost? Did you have to do much more than just remove the middle panel to replace?
Old Nov 11, 2004 | 06:14 AM
JimBlake's Avatar
Well, since I thought you were talking about a '98 Accord, ignore what I said. The Accord has a round **** that likes to break.
Integras have a cable going down to the air box, below the stereo. You can see levers & stuff if you stick your head down in the passenger footwell. Maybe the cable is broke or disconnected? The cable operates a couple levers for air dampers. Then there's a second cable going out to the heater valve just outside the firewall.
You might have to remove some parts of the dashboard or console in order to see what's broken...
Old Nov 11, 2004 | 06:56 AM
tig3rxiong's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hesh &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by Hesh at 6:00 AM 11/11/2004</TD></TR></TABLE>
hahaha...umm i dont know how to help you
Satish Patel
Oct 15, 2016 12:35 PM
eabacon025
Sep 25, 2016 02:13 AM
f22vtec1
Apr 30, 2011 06:28 AM
andyk
Feb 3, 2007 01:27 PM
Broken_Condom
Oct 19, 2004 07:48 AM
