JDM digital climate control (different question)
Old Nov 10, 2004 | 05:31 PM
aboh6leenz's Avatar
Default JDM digital climate control (different question)
Hey, a person i know has a jdm 1994 front clip of a prelude. I was wondering if i took the jdm climate control would all the other things i need:
in car temp sensor
outside are temp sensor
sunlight sensor
evap. temp sensor
power transistor
and heater valve solenoid????
If i have all these things i should be good to go with the swap right? Am i missing anything?
Thanks, got this from http://www.jrcormier.com/prelu...l.php
Old Nov 11, 2004 | 12:08 AM
aboh6leenz's Avatar
Default Re: JDM digital climate control (aboh6leenz)
someone just give me a yes or a no and tell me what i need.
Thanks
Old Nov 11, 2004 | 05:46 AM
crj_lll's Avatar
Old Nov 11, 2004 | 01:08 PM
aboh6leenz's Avatar
Default Re: JDM digital climate control (crj_lll)
wow i had that in my first post, thanks for the help???
i guess i'll just try it.
Old Nov 13, 2004 | 01:26 AM
aboh6leenz's Avatar
How about does anyone know how to make this fully functional in washington state and would liike to help me in the future? Thhanks
Old Nov 13, 2004 | 07:06 AM
thelarkascend1ng's Avatar
i'm midway through the switch right now. you will need an air mix motor otherwise your car will only blow hot or cold air. think of the slider bar on your USDM climate control. you are manually pulling a little line that tells it hot or cold (or in between). a JDM climate control is entirely digital and doesn't have that, so an air mix motor is what is going to do that job. i'm a high school student and i have to have hot air coming out by the end of this weekend, which is entirely possible, by simply getting it wired to the blower motor set for hot air. in fact, you don't even NEED the sensors really. as long as you get the unit blowing air, you are essentially wiring a cooler looking version of what you previously had, the unit can blow hot or cold air as long as you have the basic motors hooked up to it. get that mix motor, and you should be fine. better be good with a soldering iron.
Old Nov 14, 2004 | 05:33 AM
crj_lll's Avatar
Default Re: JDM digital climate control (thelarkascend1ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thelarkascend1ng &raquo;</TD></TR><TR><TD CLASS="quote"> in fact, you don't even NEED the sensors really. as long as you get the unit blowing air, you are essentially wiring a cooler looking version of what you previously had, the unit can blow hot or cold air as long as you have the basic motors hooked up to it. </TD></TR></TABLE>
Well, I know when I do my car, I want the unit fully functional not just abor to blow hot a cool air. I want the sensors so it keep tthe car interior temp at a cetail set temp. That is just me. To each their own.
Old Nov 14, 2004 | 08:15 PM
Xymox007's Avatar
holy crap that's a lot of work. i must say, looks nice.
Old Nov 14, 2004 | 08:20 PM
REMUS 13's Avatar
Default Re: JDM digital climate control (Xymox007)
Sup Xymox.
I'm from the good ol' vortex days (the off-topic forum days )
How ya been
Old Nov 14, 2004 | 09:25 PM
aboh6leenz's Avatar
Default Re: JDM digital climate control (REMUS 13)
anyone in washington state do this yet? want to do it for me, or help i'll pay some?
thanks
jarhead90crx
Oct 28, 2011 09:36 PM
Phildo916
Feb 15, 2009 04:45 PM
qazaq
Jun 30, 2008 04:31 AM
aaj23
Jun 29, 2003 08:04 AM
