how do you test the compression on a GSR?
Old Dec 25, 2001 | 08:53 AM
lowteg's Avatar
Default how do you test the compression on a GSR?
is it something anyone can do?
Old Dec 25, 2001 | 11:40 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: how do you test the compression on a GSR? (lowteg)
Yep, anyone can do it.
Hit up your local parts store and get a compression tester (about $30)
Pull all the plugs out of your engine, remove the ECU fuse, (to eliminate fuel being introduced during test) sit in the car, open the throttle all the way, and crank it for 4 (That's 4) full crank revolutions. Then stop. Read the number on the gauge, then go to the next cylinder.
Write down the numbers staring with cylinder 1 (closest to the timing belt)
They should all be within 5% of eachother. If not, then you need to do a leakdown test. (have a shop do this)
HTH
Old Dec 25, 2001 | 12:29 PM
Big Teggie's Avatar
http://www.c-speedracing.com/howto/c.../comptest.html
Check out that link. Its real easy to do. Peace
EdwinCheng
May 8, 2014 02:26 PM
mhewitt
Jan 31, 2011 03:06 AM
gs-R_swap
Oct 4, 2009 12:12 PM
tgod1020
12
Oct 9, 2003 04:29 PM
wm5holla
Mar 23, 2003 03:39 PM
