help!!! oil in spark plug holes
Old Nov 10, 2004 | 03:15 PM
copmagnet's Avatar
Default help!!! oil in spark plug holes
i was driving my car on the freeway and i thought it was running weird. when i got off the freeway it was ticking really bad and if i let off the gas at idle it would die. i barely made it home and when i parked there was blue smoke coming from under the hood so i shut off the car and poped the hood. pulled the spark plug wires and there is oil in every single one of them. what could have cuased this last time i have oil where the spark plugs were i spun a bearing. plz help me out thanx in advanced. o by the way its a 91 prelude 2.1L
Old Nov 10, 2004 | 03:34 PM
speedracer9k's Avatar
Default Re: help!!! oil in spark plug holes (copmagnet)
sounds like you blew out your piston rings....the reason why your car dies is because youur motor wont hold compression and the blue smoke is from the oil mixing with the air/fuel mixture and its getting burned
Old Nov 10, 2004 | 06:44 PM
eMpAtHy's Avatar
Default Re: help!!! oil in spark plug holes (speedracer9k)
it could also be a valve cover seal..the rubber stuff..dont know the exact name, but the thing you put on to seal the head and the valve cover
Old Nov 10, 2004 | 08:28 PM
mr abstract's Avatar
its probably your gromets. you can get those at a autozone or kragen for like 20 bucks. its pretty easy to do.
Old Nov 10, 2004 | 09:25 PM
PrettyLude's Avatar
sounds like ur rings are shot, it has to take alot of oil to make ur car just die out like that at idle.
it happened to me one time, cuz i cracked two of my pistons running a turbo
Old Nov 11, 2004 | 08:27 AM
Elkins911's Avatar
Default Re: (PrettyLude)
rings
Old Nov 11, 2004 | 08:56 PM
Default Re: (Elkins911)
do a compression test to find out exactly what is it
Old Nov 12, 2004 | 10:01 AM
limpmode's Avatar
Default Re: (speedracer9k)
i'd almost put money on piston rings. just had the same prob. it's common on H22s
Black02LS1
Dec 22, 2008 07:17 PM
EG6_978
Sep 13, 2008 02:37 PM
Nate10-1992
Aug 5, 2008 12:09 PM
Eg6xCiViCxSi
Dec 17, 2005 03:38 PM
GTEater
Nov 29, 2001 11:32 AM
