48 MM lectron carb set-up with Electromotive ignition system
Old Nov 10, 2004 | 12:45 PM
straightline's Avatar
Default 48 MM lectron carb set-up with Electromotive ignition system
For sale
These are the same carbs used by many of the worlds fastest pro stock Drag bikes in the NHRA which make over 300 WHP
For B16 Head motors ( can be modified for GSR)
-4 48 mm Fast by Gast Lectron slide carburetors
-1 Intake manifold (for B16 head)
-1 Fuel rail and gauge
-1 Holley electric fuel pump and low pressure reg.
- Earls lines, fittings, and rebuildable filter (new)
-1 AN-R insulator gasket (new)
IGNITION
-1 Electromotive programmable ignition system W/ B series trigger wheel and pick up
-set magnacore of plug wires
This is a complete set up and is all you need to run the car, No ECU Or other components needed. All fittings and lines included. The carbs are freshly rebuilt by The Carburetor shop in Milwaukee, WI (Where I work) and the carbs are currently set up for my old 2.0 LS Vtec drag motor. For questions and pictures please e-mail me or call me at 414-380-0032 ask for Dan
this set up is a steel at: $1300 FIRM Don't ask to go lower
Old Nov 10, 2004 | 01:19 PM
Default Re: 48 MM lectron carb set-up with Electromotive ignition system (straightline)
TTT^^^
Old Nov 11, 2004 | 11:00 AM
back to the top
Old Nov 17, 2004 | 09:43 AM
ttt^
Old Nov 18, 2004 | 09:50 AM
up again
Old Nov 20, 2004 | 09:47 PM
SuperTwinz's Avatar
I'm interested PM me or IM me on AIM: EK20A.
Old Nov 21, 2004 | 05:19 PM
Default Re: 48 MM lectron carb set-up with Electromotive ignition system (SuperTwinz)
pm sent
crazyjetsfan22
Jun 19, 2012 01:22 PM
K7-1Ktrevor
Engine Management and Tuning
Nov 18, 2011 10:21 AM
D-Rob
Oct 8, 2007 04:19 AM
straightline
Jul 7, 2004 02:20 PM
TriK
Sep 26, 2002 06:06 AM
