Beaks EK Quick Swap Sway Bar Kit
Old Nov 10, 2004 | 11:53 AM
JDM_EK_9's Avatar
Default Beaks EK Quick Swap Sway Bar Kit
I bought this kit a couple weeks ago and installed in on my car, followed all the instructions and installation went really smoothly. Now I have an annoying clunking noise on low speed bumps. The bar doesn't hit the exhaust or any other moving part of the suspension. I was just curious if other people have run into any problems like this.
A friend of mine that bought this same kit and actually had his passenger side endlink tear clean out of the sway bar.
http://www.beaksproducts.com/
Old Nov 10, 2004 | 12:01 PM
xhatchracerx's Avatar
Default Re: Beaks EK Quick Swap Sway Bar Kit (JDM_EK_9)
i have the same kit and i havent had any problems with it
Old Nov 10, 2004 | 12:15 PM
JDM_EK_9's Avatar
Default Re: Beaks EK Quick Swap Sway Bar Kit (xhatchracerx)
When you installed it..... did your bar stay up, I look under my car and the end links seem to be angled towards the middle of the car. I thought the end links were supposed to stay fairly vertical. Am I mistaken or is that an okay thing to have happen? I thought maybe the bar was upside down so I flipped it and re-installed it, but it still does it. If someone could help out I'd appreciate it.
Old Nov 10, 2004 | 12:22 PM
the first time i installed it i had a clunking noise because i installed the sway bar upside down, i was so eagar to test drive it i didnt even bother to check. After i reinstalled the sway bar the correct way i had no problems with it. No noises at all.
Old Nov 10, 2004 | 01:01 PM
2 point 0's Avatar
that clunking noise if from the endlinks. you probable didn't tighten it down. i had this happen to me twice. shoot it with an air gun or torque it down right.
Old Nov 11, 2004 | 09:47 AM
JDM_EK_9's Avatar
Default Re: Beaks EK Quick Swap Sway Bar Kit (2 point 0)
Figured out the problem, I had the bar on correctly but the end links were on the wrong sides, I did not realize they were driver/passenger specific. That's my fault for putting 2 and 2 together. I do appreciate your input. Every thing is installed correctly and tightened down to spec and now there are no problems. This is a great kit, but be methodical when installing, if you're over eager and rush it you run in to problems like me.
Old Dec 7, 2004 | 06:36 PM
AFTERZERO's Avatar
Im bout to install the same kit on my car....glad I read this..
confucioussae
Suspension & Brakes
Sep 13, 2006 03:03 PM
ABK
Suspension & Brakes
Aug 14, 2005 04:33 PM
MAD ITR 55
Jul 10, 2003 03:02 PM
halim
May 11, 2002 12:25 AM
