Injector wiring question.(Quick disconnect adapter plugs for different styles)
Sorry not for a honda but its still for a FI vehicle and if it works it could be done on a honda.
My friend just got a URD kit for his supercharged TRD Tacoma and it comes with bosch injectors which require you to modify the wiring harness and use the bosch clips. Here is the kit http://www.urdusa.com/Merchant..._Code=
My question is; Can you put a connector in between the adapter plug and the wiring harness so he can easily swap back to the stock injectors for smog?
The connectors I was thinking about are just simple rc car connectors like these Deans pieces. They also have very low resistance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WSDeans »</TD></TR><TR><TD CLASS="quote"> The Ultra Plug actually has less resistance, including the solder joints, than an equivalent length piece of 12 gauge wire</TD></TR></TABLE>
What do you guys think? Will this work?
Thanks
Edit: That pic above is pretty close to there actual size too.
Modified by _BEN_ at 12:49 PM 11/10/2004
Thanks
Has any one atleast seen what I'm talking about.
The only thing that has me wondering is if the resistance(if any) from the conncetor would change the way the injector pulses.
Mark Williams
Honda Civic (2001 - 2005)
Jun 29, 2019 07:48 PM
*Boostwerks*
17
Jun 20, 2004 09:02 PM
