How to keep your Boosted motor from blowing....
Well after I just fried my h22a1 with 95k on it, I have learned a few things that hopefully will allow me to preserve my new motor I am putting in soon ( jdm longblock)
Disconnect the PCV valve: A must, this just holds in pressure in the crank... which needs to be released
Hook up Wastegate right: spikes to 12-14 psi are fun, but not any good!
A newer motor hopefully wont have as much wear and tear...
Any advise or input on how to keep the motor for at least a year on 8psi? h22a
Stock motor or built motor, it's got to be tuned right. Some sort of engine management will help keep the fueling and ignition timing correct, as well as protect you from knocks. Have some good gauges so you know how everything is behaving too (I would suggest EGT, boost, and oil pressure).
it's gonna be even worse on that jdm motor. if i were you i wouldn't boost too much on it due to the high *** compression. like one of the other guys said. build the blown motor you have and for now you should just leave the jdm motor naturally aspirated if you don't want it to go as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a193 »</TD></TR><TR><TD CLASS="quote">
Any advise or input on how to keep the motor for at least a year on 8psi? h22a</TD></TR></TABLE>
Yep..
Search!
https://honda-tech.com/zerothread?id=689805
Yep..
Search!
its been tuned, it was running 9:1 a/f = fmu setup! Anyway it was due to wear and tear, spiking, and just the pressure itself.
I dont have the money to send the block off and build, if I could rebuild mine with stock pistons, new rings, and maybe thinker head gasket and studs, this would be good.
Is there any wrong in doing this, I dont know of anyplace that hones h motors here.
turbo's = money. should of had thought of that before you threw a turbo onto a h22. high compression + weak ringlands + boost=bye bye engine.
whatever u plan to do, your engine still isnt going to last longwith high compression and your turbo in there...drop in some 9.0 compression pistons new rods sleeve the block..cost you about 2000 or so to get someone to do it..and ur basically fine..might of left some stuff out, but
to lowering compression with a head gasket.
i dont have the money right now, I selling the drag kit, and going na again, na is what I wanted to do in the first place anyway....Thanks for the replies
I don't think you need to lose that FMU and invest into hondata/AEM EMS, and get it tunr before putting a new motor into the car. If you rans out of funds, your best bet is to get the turbo out and ran it with just the motor until you get the money for a standalone. To me FMU is not well tune no matter how much you tune it. I know the problem is boost spike but if you have a standalone ECU i'm sure you can ran 8 psi daily on H22
Sell the FMU and buy a Civic P28 computer. then use uberdata with properly sized injectors..
you dont need to spend lots of money if you want to have control over what your injectors AND timming are doing. just read and search.
Modified by 2point2 at 7:07 PM 11/10/2004
