Spark plug gap confusion on B16a???
Old Nov 10, 2004 | 10:42 AM
n1div's Avatar
Default Spark plug gap confusion on B16a???
I've read two different spark plug gap settings for B16a. ~.044 and ~.051. Why is there 2 different specs and which is the better one to use?
I know one is for JDM motors and other is for USDM and wondering if the different ignition maps on the ecu's better utilize the spark plug gap accordingly.
Old Nov 10, 2004 | 11:11 AM
sleepyEK's Avatar
Default Re: Spark plug gap confusion on B16a??? (n1div)
go with the tighter spec. i've used both and made no difference.
Old Apr 18, 2005 | 02:21 PM
DelSolDon's Avatar
Default Re: Spark plug gap confusion on B16a??? (sleepyEK)
bump for other opinions cause i wanna know too
Old Apr 18, 2005 | 03:43 PM
notstock93's Avatar
Default Re: Spark plug gap confusion on B16a??? (DelSolDon)
Normal NGK's for B16's use .44 gap (they are pregapped)
I would assume its not due to any ECU mapping, rather the ability to run larger gap due to thier much higher octane over there. Use the .44.
Old Apr 18, 2005 | 03:54 PM
DelSolDon's Avatar
Default Re: Spark plug gap confusion on B16a??? (notstock93)
i also read in another post that Rocket suggested .038". I always run 93 octane and I have oem dizzy style ignition.
Old Apr 18, 2005 | 03:56 PM
DelSolDon's Avatar
so, i think i ruled out the .051", and my plan is to run .040", kinda between the 2 specs. any objections or other thoughts?
Old Apr 18, 2005 | 04:17 PM
Exempt's Avatar
Id go with the .040, as most Hondas Ive seen the specs on have used that gap... And def go NGK, but just cuz theyre 'pregapped' check them anyway! I just did my brothers car, and the pregapped .040 were actually much smaller...
Old Apr 18, 2005 | 04:30 PM
LSVTEC 91 Civic's Avatar
Banned
I gap at .040
southernSCHEME
12
Sep 29, 2010 12:22 PM
the.hamburglar
Jul 7, 2005 09:36 PM
asiansgoweeee
Jul 3, 2005 10:13 PM
thinknology
May 27, 2004 02:15 PM
evil_elmo
Jan 22, 2002 08:01 AM
