Anyone have a k20 spec sheet?
Old Nov 10, 2004 | 10:40 AM
partsguyonline's Avatar
Default Anyone have a k20 spec sheet?
Does anyone have a spec sheet on the different kinds of k20 engine?
Old Nov 11, 2004 | 04:39 AM
6SPD_EK's Avatar
Default Re: Anyone have a k20 spec sheet? (partsguyonline)
been covered before - search archive topics or go to honda.com (k20a3 is civic si) or acura.com ('05+ RSX-S)
02-'04 K20a2
Bore: 86mm
Stroke: 86mm
Deck height: 212mm
Rod length: 139mm
Intake Valve: 35.15mm
Exhaust Valve: 30.15mm
Compression Ratio: 11:1
Displacement: 1998cc
Power (bhp@rpm): 200@7000
Torque (ft/lbs@rpm): 142@6000
K24
Bore: 87mm
Stroke: 99mm
Compression Ratio: 9.6:1
Displacement: 2354cc
Power (bhp@rpm): 160@6000
Torque (ft/lbs@rpm): 162@3600
jdm k20a
HP 220 @ 8000RPM
Torque 152 lb/ft @ 7000 RPM
Redline 8400 RPM
Bore 86mm
Stroke 86mm
Comp Ratio 11.5:1
Displacement 1998cc
Specific output 110HP/L
Trans Specs (k20a - type r)
1st 3.27:1
2nd 2.13:1
3rd 1.57:1
4th 1.21:1
5th .97:1
6th .78:1
Final Drive 4.76:1
Old Nov 11, 2004 | 07:49 AM
Default Re: Anyone have a k20 spec sheet? (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">been covered before - search archive topics or go to honda.com (k20a3 is civic si) or acura.com ('05+ RSX-S)
I was searching but didn't see. Thnx for the info
bambam
29
Sep 16, 2012 02:36 PM
civic_minded1987
Honda Civic (2001 - 2005)
40
Nov 22, 2006 03:53 PM
turnsignalandy
56
Nov 11, 2006 08:02 AM
K20EG
48
Nov 8, 2003 10:29 AM
Cyber ITR
May 16, 2002 05:09 PM
