b20vtec VS. B18c5
I had a c5 swap then rebuilt it to a 2L and that **** is much faster! ET's on street tires were .5 seconds better eventually getting into the 13's...
The power of the 1.8 was 193/134
and the 2.0 was 194 and 145...untuned
2.0L owns the 1.8's
2.0L owns the 1.8's
mine was an 89mm crank w/84mm bore(sleeved type-r block) with compression about equal as a stock ITR.
If your talking about a stock b20b block w/ a vtec head,id say go with a straight ITR engine. If you plan on building it up,I say go with something 2Liters. The extra torque will make you grin and youll be glad you did...
B20 might end up making more power but will not be as durable. I would drive a b18c5 to the max all the time. I would be afraid to do the same to a modified b20.
Well, I've pretty much decided to go with a b20. I'm going to be completely rebuilding it so I don't think the "stock" flimsiness of the b20 is going to be a problem. And very good point about the ITR Tranny. That's why I'm probably still going to use the tranny
LSVTEC?/B20 CRVTEC..WHICH WOULD YOU DO AND WHY..WHATS THE PURPOSE FOR BUILDING A CRVTEC?ADVANTAGES O
IntegraGSR(-1)
Jun 21, 2005 05:14 PM
JdmHybrid.
52
Jun 16, 2003 11:24 AM
