Valve Springs
Old Nov 10, 2004 | 08:21 AM
mikebaglini's Avatar
Default Valve Springs
Can anyone tell me if there is a difference between the Honda valve springs on the B18a and B18b. My manual is for a 1990-1993 and my 1995 LS valve springs are below the service limits ... just wondering if the spring free length would be different on the 1994-2000 LS models.
Mike
b18a block, b18b LS head
Old Nov 10, 2004 | 09:24 AM
Rocket's Avatar
Default Re: Valve Springs (mikebaglini)
Not sure about this.
But are you rebuilding the head?
Old Nov 10, 2004 | 04:19 PM
Default Re: Valve Springs (Rocket)
Not really rebuilding per se... resurfacing the valve seats and grinding the existing valves, mild porting and all new seals and gaskets... Just replacing things that have exceeded the service limit and so far it appears like the valve springs need to go if the specs are the same as the 90-93 generation.
Mike
Old Nov 10, 2004 | 04:24 PM
Rocket's Avatar
Well, the stock ls springs are pretty soft to begin with and prolly lost some tension over time so using them in a performance application with a higher rev limit and perhaps lighter parts is kinda risky.
We have nice single springs for the LS and are affordable. Just something for you to think about.
JdmLsPwr425
Aug 4, 2005 01:30 PM
JdmLsPwr425
Sep 22, 2004 07:33 PM
Lamchop0000
May 26, 2003 08:02 PM
smdandb2
Oct 16, 2002 11:36 AM
