Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
*** 4x100 --> 4x114.3 Wheel Adapter ***
Old Nov 9, 2004 | 11:17 PM
jarel's Avatar
Default *** 4x100 --> 4x114.3 Wheel Adapter ***
Hey guys. I was wondering if anyone has every used one of these on a Honda (preferably CRX) any models. Would it be ok to run this with a ITR 4-lug rim or any Honda offset 4x114 rim? This spacer kicks out the rim 30mm (roughly 1.2 inches or so). how would it look on a honda?
Anyone with experience with these??
EBAY LINK
http://cgi.ebay.com/ebaymotors...42614
Old Nov 9, 2004 | 11:20 PM
LX4CYL's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (jarelee)
Those look like a disaster waiting to happen. Try not to drive too fast if you do buy them
Old Nov 10, 2004 | 12:40 AM
B18OnTop's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (LX4CYL)
What are those studs made of?
-Aaron
Old Nov 10, 2004 | 01:35 AM
rice_classic's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (B18OnTop)
I've been reading about spacers lately and I'm find MANY responses that say they are a bad idea. Some say that they can be a weak link and others say that they ruin hub bearings. Others say that the added width of the wheel base won't actually increase stability because it changes the suspension geometry.
Research opinions on the WHOLE internet before you try those....
IMHO I WOULD NEVER TRY THOSE!
Old Nov 10, 2004 | 06:09 AM
jarel's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (rice_classic)
lots of good points....thanks for the info guys.
Old Nov 10, 2004 | 06:14 AM
toEknEEg's Avatar
i wouldnt try it... imo
Old Nov 10, 2004 | 06:22 AM
Want2race's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (toEknEEg)
I would, try them!
Many professional racing teams in the past have used them.
does it wear out bearings faster? Probably but doubtfully noticeable.
Its a well engineered idea. Its not too different to running a different hub as far as stress loads. As long as the bolts hold it should not be a problem
Old Nov 10, 2004 | 07:26 AM
jarel's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (Want2race)
i WOULD try it....but custom fabricated ones...not generic ones off of Ebay.
But i was just asking in general
Old Nov 10, 2004 | 09:08 AM
JeffS's Avatar
Honestly, this sounds like an appearance forum post.
Spacers are one thing, but who in here can honestly say they're running a 30mm spacer?
All because you want to run some stock wheel that's not any better suited than the hundreds of 4x100 options on the market?
Old Nov 10, 2004 | 07:28 PM
jarel's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (JeffS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">Honestly, this sounds like an appearance forum post.
All because you want to run some stock wheel that's not any better suited than the hundreds of 4x100 options on the market?</TD></TR></TABLE>
these aren't to be put on a show car, i figured road racers might use spacers to have wider rims/tires...thas why i put it in here. Because someone might have experience with spacers here, rather then the "show-ho's" in the appearance forum
Old Jun 4, 2006 | 09:35 PM
2slowGs-R's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (jarel)
one of my cousin is running spacers like that on his blue delsol with jdm itr wheels and it seems to be ok just that the wheels sit out a bit but is flush with the fenders though! i think its an okay idea....
Old Jun 4, 2006 | 11:05 PM
KOALA YUMMIES's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (2slowGs-R)
Many of the spacers by some well known suspension companies are essentially the same exact thing (though usually hubcentric to boot), they're all over Japan too, they like their wheels to stick waay out .
Old Jun 5, 2006 | 03:53 PM
HapaHaole's Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (KOALA YUMMIES)
besides messing with your scrub radius, those things dont have a wheel register on them. If they did, then maybe I'd consider using them to rock them JDM ITR wheels.
Old Jun 5, 2006 | 09:59 PM
mos's Avatar
mos
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (HapaHaole)
So where do you get 70mm offset wheels?
Old Sep 18, 2007 | 09:06 AM
EF9 JAMS!!!'s Avatar
Default Re: *** 4x100 --> 4x114.3 Wheel Adapter *** (mos)
i would rock this, but someone enlighten me on putting these on a ef9 please
luke1978
Feb 1, 2014 08:25 AM
Shaguar47
Dec 27, 2011 04:38 PM
darkspector
Jun 24, 2006 12:30 AM
jarel
Nov 19, 2004 01:33 PM
