hey guys i am haveing problems with brakes. i need help!!!!!!!!!!!
Old Nov 9, 2004 | 06:31 PM
civichatch52687's Avatar
Default hey guys i am haveing problems with brakes. i need help!!!!!!!!!!!
i have a eg htch i just bought it and it has been sitting for awhile and after i driv my car for awhile the brake wil start to go farther down , until it hits the floor. I thought it might be mymaster cyclinder but i dont see any leaks. if u kno anything please let me kno.
Also i just recently installe a new clutch and it has alot of play in it , and it seems to grab different , after awhile , if u can give me some answers please get back to me asap , its a hydro tranny if it makes any diffenence.
thankss
Old Nov 9, 2004 | 06:33 PM
sleepyEK's Avatar
Default Re: hey guys i am haveing problems with brakes. i need help!!!!!!!!!!! (civichatch52687)
is there any fluid noticeable on the inside of the car? sometimes they leak internally as well.
Old Nov 9, 2004 | 06:42 PM
drdisco69's Avatar
Default Re: hey guys i am haveing problems with brakes. i need help!!!!!!!!!!! (sleepyEK)
You won't see the master cylinder leaking, it's the seals inside. Put a master cylinder on it.
For the clutch, try bleeding it.
Old Nov 9, 2004 | 06:43 PM
burnout289's Avatar
have you bled the brakes? air trapped in the lines will make the pedal softer and travel farther.
also, try and look around the calipers and brake hoses in and around the wheels. and in the rear [if drums] look at the backside of the drums [meaning the inboard side] so see if they are wet. I had wicked brake fluid leaks on my mustang but no drips on the ground. just happened to drip on other parts and collect dirt and turn into some kind of funky goo.
pedroa06
Sep 3, 2009 06:23 PM
h22lude317
Mar 2, 2009 09:06 PM
boost97gs
Nov 2, 2004 03:53 PM
Terminator Sol
May 17, 2004 08:20 AM
crxtreme27
May 19, 2003 12:04 AM
