drivability with cams and springs in but not tuned
Old Nov 9, 2004 | 06:22 PM
qcktegls's Avatar
Default drivability with cams and springs in but not tuned
i wanna put in the crower 403's with the valve springs in a garage by my house and then drive to the local dyno shop to tune the hondata s100. is the car still drivable after those installs? i dont wanna hurt nething driving that distance and i dont wanna pay for the instal. so if ne one knows send it this way. thanks
Old Nov 9, 2004 | 06:33 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: drivability with cams and springs in but not tuned (qcktegls)
It's definitely driveable. Just don't modify the cam gear settings (leave them at 0 degrees) and you'll be fine.
Old Nov 9, 2004 | 06:38 PM
qcktegls's Avatar
Default Re: drivability with cams and springs in but not tuned (shamoo)
so nothin is gonna break and im not gonna mess nething if i drive it a couple miles? should i stay under a certain rpm or a certain speed?
Old Nov 9, 2004 | 06:41 PM
B18OnTop's Avatar
Your fine if you keep the cam gears at 0 degrees. When you start the car let it idle for about 15-20 min to break in the cams. Then your good to go.
-Aaron
Old Nov 9, 2004 | 06:48 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qcktegls &raquo;</TD></TR><TR><TD CLASS="quote">so nothin is gonna break and im not gonna mess nething if i drive it a couple miles? should i stay under a certain rpm or a certain speed?</TD></TR></TABLE>
Nope, nothing is going to break. As long as everything was installed correctly and the cam gears are still set to 0, you'll be fine. Provided your valves are not TOO loose after the install, you can rev to redline all day and still be fine without tuning.
Old Nov 9, 2004 | 06:51 PM
qcktegls's Avatar
thanks a lot fellas uve been a big help. looks like those cam gears and valve springs are goin in sooner than i thought.
HondaTeg95
Aug 26, 2005 07:10 PM
.dave
Aug 19, 2005 10:20 AM
youngvedder
Jan 20, 2005 04:35 PM
95BlkGSR
May 7, 2004 07:41 PM
flyrod
Oct 23, 2002 11:57 AM
