Oil Pressure Guage
Old Nov 9, 2004 | 04:50 PM
CivicSiDriver02's Avatar
Default Oil Pressure Guage
I bought an Autometer electronic oil pressure gauge a few weeks ago, but i was wondering if you replace the stock oil pressure switch with the sending unit included with the gauge kit will you throw a code and/or put you into limp mode? If so how should I hook it up so that this does not happen? Thanks in advance!!
Old Nov 9, 2004 | 05:16 PM
red92si's Avatar
use a t-fitting...
Old Nov 10, 2004 | 09:48 PM
PrettyLude's Avatar
Default Re: (red92si)
use a t-fitting...
Old Nov 10, 2004 | 10:40 PM
TimeRacer's Avatar
Default Re: (PrettyLude)
Use a T fitting, but NOT into your block. Use a normal BSPT fitting into the block, run a line off the block to a place where you can secure your T fitting and then put put the OEM sender and your new sender there. Make sure to ground it as well.
Built4Battle
Nov 2, 2011 11:39 AM
dirtracer63c
Mar 7, 2010 08:08 AM
afplayboy17
Oct 6, 2007 10:39 AM
danny_civic97
Mar 12, 2007 01:00 PM
Alstare
Sep 5, 2005 03:10 PM
