SPARK PLUG TUBE SEAL: IN THE PROCESS NOW!!!
Old Nov 9, 2004 | 04:37 PM
DrewQ1's Avatar
Default SPARK PLUG TUBE SEAL: IN THE PROCESS NOW!!!
I took off the valve cover and took out the spark plugs but i see no spark plug tube seals, so where would i put the new ones i have, help me out cause i'm doing right now and i dont see anything.
Old Nov 9, 2004 | 04:42 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: SPARK PLUG TUBE SEAL: IN THE PROCESS NOW!!! (DrewQ1)
Look underneath the valvecover, on each plug hole there should be a groove around it where you put in the new seals.
Old Nov 9, 2004 | 04:45 PM
DrewQ1's Avatar
Default Re: SPARK PLUG TUBE SEAL: IN THE PROCESS NOW!!! (ThE bEe GuY)
What about the old ones i didnt see any.
Old Nov 9, 2004 | 04:48 PM
boosted k20's Avatar
well if u never had any then u would have alot of oil in ur spark plugs. somtimes the seals are still stuck onto the valve cover. look on the inside of the cover where the 4 wholes are for the spark plugs. u should see 4 rubber rings on there. if there not on the valve cover then they should still be on the head. if it's not then who ever had the car b4 u is really stupid
potatointegra01
Apr 14, 2015 03:49 PM
jose310
Jan 12, 2009 01:38 PM
t0kyoStatus
Nov 26, 2008 07:05 PM
Jokergp
Sep 3, 2008 10:54 AM
Red_Si
Oct 26, 2006 10:48 AM
