Intake manifold Throttle Body setup
Engine: 1.8 liter with mild compression and cams, street/track car.
Goal: 200whp
Details:
LS/VTEC with high 11.x:1 compression.
PR3-3 head, with headwork, BCstage3+ cams and Omnipower valvetrain.
Right now ITB's and AIR IM are out of question, simply that this will be a street car.
I was wondering what TB, IM combo would fit this setup.
From research I don't think I would benefit from anything over 65mm when it comes to the TB.
Lets hear your advice or lists your setup!
TIA.
Goal: 200whp
Details:
TIA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldSchoolSwap »</TD></TR><TR><TD CLASS="quote">Maxbore tb and Pro Products (AEBS) mani. </TD></TR></TABLE>
That's what I'm leaning to right now on TB.
Still been hearing good things about Blox.
extrude hone is an expensive process that will net little gain. Send it to a porter. You're entirely correct that a 65mm throttle body plate side will be more than enough. There's a lot of 'stunnas' that throw a 70mm throttle body on their mild cars.
Im using the blox IM on my new motor, just a basic copy of S2 manif. But quite alot cheaper. The R manifold and TB is a good established set up. mabye a little bigger tb, but you can make 200 easy with that IM and TB if everything else provided is up to the task.
-s
-s
itr1244
Jul 9, 2018 06:33 PM
SilverWarrior
48
Dec 12, 2012 07:31 AM
r33dm0n3y
25
Jul 8, 2009 07:09 AM
SilverWarrior
11
Oct 19, 2007 09:51 PM
