what to do? faulty brake master cylinder
Old Nov 9, 2004 | 12:27 PM
LAKER HATER's Avatar
Default what to do? faulty brake master cylinder
the brake master cylinder is going bad. when i push on the brake, it almost reached the floor. i think its probably old and worn out. what should i do? should i replace it? or could it be the result of bubbles in the brake lines? what do you think?
if i need to replace it, how hard is this? how much does the part usually go for? this is for a 90 integra LS
Old Nov 9, 2004 | 12:47 PM
rgaray's Avatar
Try bleeding it. If it doesn't work, then replace. $60 from Autozone.
Old Nov 9, 2004 | 08:01 PM
stumpyf4's Avatar
Default Re: what to do? faulty brake master cylinder (LAKER HATER)
If you pump it a few times does it raise the pedal somewhat... if it does defintely the master cylinder on it's way out... replace it.
If the pumping does not raise the pedal it may be air in the line, try bleeding.
Old Nov 10, 2004 | 04:34 AM
JimBlake's Avatar
Default Re: what to do? faulty brake master cylinder (stumpyf4)
In my experience it's been the other way around.
Air in the lines... Mushy pedal at the very beginning, pump it & it gets better.
Bad MC... Brake pedal is hard, but then slowly & smoothly sinks.
Old Nov 10, 2004 | 04:36 PM
JamaicanDM's Avatar
Default Re: what to do? faulty brake master cylinder (JimBlake)
if there is liquid on the driver site floor or the pedal goes to da floor while braking, then u need to replace it
ribal_gh
11
Apr 30, 2013 04:24 AM
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
bb4socal
Sep 4, 2006 09:51 PM
PHOBIA
Jan 21, 2005 07:36 PM
The_In_Kid
Jul 7, 2002 11:45 PM
