98 accord...idle drops...please read.
1998 Honda Accord F23a1 Vtec 150 HP
Here is the problem:
After going through the gears, and letting off the gas(like when you come to a stop sign) the car's idle will drop and almost stall. A few seconds later it pops up again. It has NEVER done this when I rev the car when stopped, only happens during driving.
I have replaced:....plugs, wires, cap, rotor, and fuel injector cleaner...
Result: Idle is not speratic, nor lower then normal any other time then when the problem occurs. I have a cell code 67 which indicates a random misfire. The cel will go away and not return for hours if I reset the computer but even without the cell, the idle problem is present.
Any ideas will be appriciated greatly!!!!
CPL
Aug 24, 2004 05:41 PM
