Identifying Engine Year. Grabbed All Codes I Could See
Old Nov 9, 2004 | 11:07 AM
1 Cam Wonder's Avatar
Default Identifying Engine Year. Grabbed All Codes I Could See
Trying to identify the year of my engine so I can find if the tranny I just bought was swappable.
Here are the numbers I snagged, motor is a Sohc Zc non vtec
Tranny code L3 1386243
Just some codes I grabbed off of my engine are
-PM3 - 3
5733267
Is there any more to tell from? I just grabbed what I could see quickly with the flashlight?
If that doesnt tell you anything LMK where I grab it from
Thanks
Old Nov 9, 2004 | 11:47 AM
91civicEX's Avatar
Default Re: Identifying Engine Year. Grabbed All Codes I Could See (1 Cam Wonder)
year of the engine doesnt matter. what year was the old tranny? originaly in the car? what year is the new tranny? only 88 is not compatible with 89-91 clutch. buy the same year clutch that the tranny is.
Old Nov 9, 2004 | 01:21 PM
CRX_Control's Avatar
Default Re: Identifying Engine Year. Grabbed All Codes I Could See (91civicLX)
dont forget to use the same year flywheel
Old Nov 9, 2004 | 03:22 PM
riceisnicenv's Avatar
Default Re: Identifying Engine Year. Grabbed All Codes I Could See (CRX_Control)
if you look between the 2nd and 3rd cylinder exhaust ports, there should be a number. that number is the year your engine is. if i'm wrong someone please correct
Old Nov 9, 2004 | 10:19 PM
Default Re: Identifying Engine Year. Grabbed All Codes I Could See (riceisnicenv)
That true?
Ill check it up in the mornin
Old Nov 9, 2004 | 10:26 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder &raquo;</TD></TR><TR><TD CLASS="quote">That true?
Ill check it up in the mornin</TD></TR></TABLE>
Yep. Look above the header. It's labeled 8/8, 8/9, 9/0 or similar.
brodyl05
Mar 25, 2007 06:18 AM
alupso
24
Jan 24, 2006 12:08 PM
GruvyTune
Jan 11, 2003 06:02 PM
Cereal_Killer
Dec 12, 2002 10:38 PM
