B18A Head Milling
Old Nov 9, 2004 | 08:41 AM
Kzoorice's Avatar
Default B18A Head Milling
We are running through my buddie's motor to make sure everything is cool with it before we drop it into his CRX. . .
We were thinking about milling the head to bump up the compression a tad bit. I was curious if anyone on the site has done this with the LS motor and how much the milled. I searched and found a variety of results. But if someone has personally done it. . not. . my friend did this or that. . .then I would like to know the specs YOU used. I was thinking of just going .05 but i would still like to know what the compression ratio is after milled if anyone knows how to calculate that. I have heard of .07 but I want to be safer then sorry when it comes to this kind of thing. I dont want to have to replace my friend's head and valves. . heh. . .
Travis
http://www.kzoorice.com
Old Nov 9, 2004 | 09:00 AM
mmuller's Avatar
Mad Scientist
Default Re: B18A Head Milling (Kzoorice)
if you take .05 that will be almost a point up in compression.
remember also you gonna have to get cams gears to make up to make up for cam timing
for compression needs, not completely right, but close:
http://www.c-speedracing.com/h...c.php
00Red_SiR
Feb 25, 2007 05:19 PM
AlwayzSpoolin
Jan 17, 2007 05:53 PM
candy eg
Jun 28, 2006 01:38 PM
b20powereDA
Jan 27, 2006 08:35 PM
Blaise
Oct 17, 2004 05:54 AM
