What ECU can I run a 96-98 H22 head w/ on EG
Old Nov 9, 2004 | 06:37 AM
IloveAPC's Avatar
Default What ECU can I run a 96-98 H22 head w/ on EG
I always hear people putting the 94 etc. H22's in an EG but If I ran a 98 H22 could I still run a p28 chipped or something straight to the existing wiring harness. Cuz I wanted to put the newer motor in a CX
Old Nov 9, 2004 | 07:45 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What ECU can I run a 96-98 H22 head w/ on EG (IloveAPC)
if it is a usdm h22 there is a sensor that isnt used, CKF sensor, but you should be able to use your harness with a resistor box, h22 injectors are low impedence (CORRECT IF WRONG) and a chipped p28. you should be ok.
Old Nov 9, 2004 | 12:50 PM
IloveAPC's Avatar
Default Re: What ECU can I run a 96-98 H22 head w/ on EG (boostedcivicsir)
Would it be easier running the 92-95 obd1 H22? And is there any diff between the 92-95 or the 96-98?
Old Nov 9, 2004 | 02:37 PM
IloveAPC's Avatar
upperz
h22dx
Sep 6, 2010 04:04 PM
A-Star
Dec 2, 2008 10:32 AM
Keeper1343
Sep 5, 2007 06:15 PM
