92 Accord B16A throttle body?
Old Nov 8, 2004 | 08:39 PM
zumiez007's Avatar
Default 92 Accord B16A throttle body?
Alirght, doing my nightly ebay searching and came across a B16A throttle body for a great price. I'm wanting if you (all knowing honda masters) would recomend swapping throttle bodies for my stock one? Or am I better off with the stock one?
92 accord EX (F22A6)
Thanks
Also, it says that it doesn't include a TPS sensor, can the stock TPS sensor work?
Old Nov 9, 2004 | 12:10 AM
patastinky's Avatar
Default Re: 92 Accord B16A throttle body? (zumiez007)
stock one is best.. You already have the f22a6 which is the most powerful out of all the 90-93 accord motor's (f22a1, f22a4)
Besides you CAN NOT swap a B-series IM on a F-series motor..
Old Nov 9, 2004 | 05:19 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 92 Accord B16A throttle body? (patastinky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky &raquo;</TD></TR><TR><TD CLASS="quote">Besides you CAN NOT swap a B-series IM on a F-series motor.. </TD></TR></TABLE>
He never said IM, he said throttle body.
To the orginal poster, I have no answer for your question.
Old Nov 10, 2004 | 10:02 AM
zumiez007's Avatar
Default Re: 92 Accord B16A throttle body? (TouringAccord)
anyone have an answer to my question? Would swapping a B16 throttle body for a F22 throttle body show improved performance?
Old Nov 10, 2004 | 11:56 AM
hawkmgc's Avatar
Best thing to do is to look up the MM of the TB.
If its a factory set of 32mm and the replacement one is a 53mm then you would be increasing.
Most TPS can bolt onto others.
As so many have told me look it up.
Personally I would stick with the F22A6 one and have it bore out or buy a HP one. Just my opion. As I am changing my F22A4 intake with an F22A6 one.
should have bought the whole motor, but on well. Maybe next time I am out I will nab it.
shawnvtecordie
Feb 9, 2018 07:35 AM
nghtshd88
May 9, 2011 08:19 PM
JDMcivicRacing
Aug 5, 2005 01:59 AM
K-Drum
Sep 22, 2004 12:29 PM
