Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spherical Trailing Arm Bearing Cup
Old Nov 8, 2004 | 07:02 PM
ATS*Mark's Avatar
OG triple OG
Default Spherical Trailing Arm Bearing Cup
im wondering about these on a street car . why are they recomended for racing only? would street driving be dangerous with these?
Old Nov 8, 2004 | 07:09 PM
prkiller's Avatar
Default Re: Spherical Trailing Arm Bearing Cup (OnePointSicks)
Why would you want to use anything like that on the street? If you start changing things like these, it makes the ride so crappy on the street that you don't want to drive the car anymore except on the track!
Speaking from experience!
I am actually more curious to know if anyone is using these in their race cars? How do you like them and what did it improve?
Old Nov 8, 2004 | 07:10 PM
.RJ's Avatar
.RJ
Default Re: Spherical Trailing Arm Bearing Cup (prkiller)
I'm not sure you'd even want a spherical bearing there.
Old Nov 8, 2004 | 08:13 PM
slammed_93_hatch's Avatar
Default Re: Spherical Trailing Arm Bearing Cup (.RJ)
i seem to remeber in the thread about the trailing arm bushing and why the poly ones are bad, some one posted up a J's racing one and no one replied
Old Nov 8, 2004 | 08:16 PM
.RJ's Avatar
.RJ
Default Re: Spherical Trailing Arm Bearing Cup (slammed_93_hatch)
https://honda-tech.com/zerothread?id=493789
Old Nov 8, 2004 | 08:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">anyone try these from j's ?
looks like it can pivot and twist</TD></TR></TABLE>
yep, anyone with the knowledge care to comment on that?
Old Nov 8, 2004 | 08:22 PM
.RJ's Avatar
.RJ
Doesnt look like that would actually do anything to prevent the toe change under droop/bump....
Old Nov 8, 2004 | 08:43 PM
LX4CYL's Avatar
pfft, trailing arms are old skool
Old Nov 8, 2004 | 08:51 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Spherical Trailing Arm Bearing Cup (LX4CYL)
i just came across them and thought id ask.....
Old Nov 8, 2004 | 09:07 PM
stormy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
yep, anyone with the knowledge care to comment on that?</TD></TR></TABLE>
um there J's and there shiny chromapurpely
Old Nov 8, 2004 | 09:09 PM
Default Re: Spherical Trailing Arm Bearing Cup (sans)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sans &raquo;</TD></TR><TR><TD CLASS="quote">
um there J's and there shiny chromapurpely </TD></TR></TABLE>
I meant if they were worth a ****/
Old Nov 9, 2004 | 01:05 AM
ATS*Mark's Avatar
OG triple OG
is there a problem with running them on the street?
Old Nov 14, 2004 | 09:04 AM
eg6vtec1's Avatar
just saw this, this should clear up the skepticism.That version is the race version where most classes require the use of all the factory pick up points, and also the bearing slides back and forth on the steel shaft when the suspension travels up an down wich could make noise in bad weather or very long road trips, cars with race suspension wich have only a few inches of travel during driving should'nt have any problems on the street, 8K on my friends car no problems at all. A street verion will be released in about two weeks, same part except the steel shaft is fixed to the bearing and does'nt slide, with this design you must remove the toe link, the steel shaft will have slotted holes and toe will be adjusted. Also I must say for those who have'nt thought about this, sphericals don't necessarily make your car grip harder and pull more g's thus faster lap times, the bigest difference is the increased stability and faster response especially at higher speeds, the more stable your car feels the faster your going to drive it. My car has full sphericals and it feels nothing like my friends cars with bushings.
Modified by eg6vtec1 at 3:32 AM 11/15/2004
Old Nov 14, 2004 | 09:29 AM
eg6vtec1's Avatar
oh ya the evo 8 has sphericals from the factory, what ever kind of sphericals you had probably had all kinds of play or you probably were'nt using teflon lined bearings, my car don't make any noise, all your bearings and missalignments have to be press fit and have no play and there will be no noise, ruff ride ya a little more than stock but its not bad at all, GO DRIVE AN EVO 8
Old Nov 14, 2004 | 11:17 PM
Rostr02's Avatar
Default Re: Spherical Trailing Arm Bearing Cup (eg6vtec1)
Does any body offer a full spherical bushing set for the ef chassis?
Old Nov 15, 2004 | 04:38 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6vtec1 &raquo;</TD></TR><TR><TD CLASS="quote">oh ya the evo 8 has sphericals from the factory, what ever kind of sphericals you had probably had all kinds of play or you probably were'nt using teflon lined bearings, my car don't make any noise, all your bearings and missalignments have to be press fit and have no play and there will be no noise, ruff ride ya a little more than stock but its not bad at all, GO DRIVE AN EVO 8 </TD></TR></TABLE>
Which ones are spherical in an EVO?
Old Nov 15, 2004 | 10:46 AM
EdoMoto's Avatar
Default Re: Spherical Trailing Arm Bearing Cup (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
Which ones are spherical in an EVO? </TD></TR></TABLE>
Maybe the ones in the drivers head?
Old Nov 15, 2004 | 10:47 AM
Default Re: Spherical Trailing Arm Bearing Cup (ITAIntegraLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITAIntegraLS &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe the ones in the drivers head? </TD></TR></TABLE>
Rumor has it that pretty much all bushings are in fact spherical bearings covered with rubber b00ts...this is like 3rd hand info though...and one of the sources was .RJ....so dunno the worth
Old Nov 15, 2004 | 10:54 AM
.RJ's Avatar
.RJ
Warren is the one that told me, so blame him
Old Nov 15, 2004 | 10:55 AM
yah, but j00 suck at the game of telephone...he could have said: "EVOs do NOT have spherical bearings ANYWHERE"...for all i know...
Warren, j00 lurker, where j00 at?
Old Nov 15, 2004 | 12:54 PM
Jon V's Avatar
Interesting...
Old Nov 15, 2004 | 01:26 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Spherical Trailing Arm Bearing Cup (Jon V)
im thinking about getting them as the prothane and es bushings are not too popular.
Old Nov 15, 2004 | 07:28 PM
Rostr02's Avatar
anyone for a good spherical bushing set for a crx?
Old Nov 15, 2004 | 09:44 PM
EG_H2B's Avatar
Default Re: Spherical Trailing Arm Bearing Cup (Rostr02)
actually my FACTORY EVO8 has spherical bearings in the rear LCA's, as do all Evo's.
Old Nov 16, 2004 | 04:40 AM
Roadracejunkie's Avatar
Default Re: Spherical Trailing Arm Bearing Cup (JS_TypeR)
I have a spherical bearing set up for the crx/civic 89-91 for the front cross member, and lower control arms at the rear or the front.
I have a pic that I can email you, it's not posted the web yet, for the rear swing arm, it is a poly bushing cast into a steel shell, it is stronger than the Mugen bushing and streetable as well.
I am not bragging here ok, just wanted to mention some experience I have with bushings in the crx, in 10 years of developement on the racetrack with the crx, I have found a set up that works well, and doesn't rip out bushings in the car. It is an odd mix of different parts, not a "one stop shop" type of kit. I have all the info. on the suspension and the set up data once installed, and it worked. Ask anyone here in the cendiv scca or nasa mwhc and they will tell you, that my car handled extremely well and the car was tight, not slang, you could feel the "solidness" of the car all the way through the corner, entry,apex, and exit....
If you email me, I will reply with the bushing pic for the trailing arm I think your looking for. Crx Lee can attest, (not that he is obligated to do so), that when he ran ita with us a few years back, we had a great handling car.
In the meantime I will get the pics posted on my site so you guys can see them.
http://www.sntautosports.com
I am not trying to pull my own chain here ok, just sharing some data I have compiled over 10 years of finding what works and what doesn't.
I wouldn't suggest a full on spherical set for the street, the bumps will just destroy the bearing seats, you need some rubber to absorb the shock and undulation of the road. Sphericals are great for a smooth surface, aka road course, but I would not want to run them on the street, unless you feel like replacing them after 15k miles, in other words one a year, there just isn't enough benefit from the bearings on the street to warrant the increase in cost over poly bushings.
