2gen DSM injectors w/ OBDI Honda clips
Quick question... I was test fitting a set of 97 Eclipse injectors on OBDI Integra injector clips. It fits, however there is a small boss/tab inside the DSM injector (near the 2 metal prongs)that prevents it from going all the way into the honda clip. However, the 3 external tabs/bosses line up perfectly.
Is this normal? I was under the impression it was a plug and play situation. I can cut the boss/tab out of the injector if thats what needs to be done.
Also, the Honda O-ring that sits inside the intake manifold doesn't have the correct ID to fit around the fatter DSM injector. Which O-ring do you use?
Thanks.
[Modified by G3-TEG, 2:51 PM 12/24/2001]
Thanks.
Damn! I was gonna try this too!
What size dsm injectors are you gonna use?
If you find a good plug and play solution, pleas post it up!
Otherwise, resistor pack splicing.....
turbotime
May 14, 2006 02:33 PM
