My 3" exhaust project, 4G civic hatch
Old Nov 8, 2004 | 06:03 PM
xci_ed6's Avatar
Default My 3" exhaust project, 4G civic hatch
cut entirely w/ a hacksaw, welded witha Lincoln MIG 100 er something like that.
Old Nov 8, 2004 | 06:12 PM
mrbsponge's Avatar
man that looks pretty nice, but isnt that an overkill with such a small, bottleneck of a collector
Old Nov 8, 2004 | 07:03 PM
cstay's Avatar
Default Re: (mrbsponge)
yeah def do somthing about that flange
nice work tho
Old Nov 8, 2004 | 07:24 PM
shauniewalnuts's Avatar
Default Re: (cstay)
looks good what gauge did you use? and where did you get your tubing?
Old Nov 9, 2004 | 03:57 AM
xci_ed6's Avatar
Default Re: (shaun311)
i should have mentioned, i put that flange on to connect to a header while im finishing collecting turbo parts, I will be going to a 3" down pipe as well.
Bends were from ebay, straight sections were from summit, i think.
Old Nov 9, 2004 | 04:24 AM
cstay's Avatar
Default Re: (krustindumm)
Old Nov 9, 2004 | 11:52 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">i should have mentioned, i put that flange on to connect to a header while im finishing collecting turbo parts, I will be going to a 3" down pipe as well.
Bends were from ebay, straight sections were from summit, i think.</TD></TR></TABLE>
Looks good , rough estimate how much did you pay ?
Old Nov 10, 2004 | 03:41 AM
xci_ed6's Avatar
Default Re: (90blackcrx)
The muffler was ~$75, the U-bends (2 needed) were ~$25 each, and the straight section was ~$25 for the long one and $5 for the short one. Came out to around $155, plus it took 2 spools of wire ($8/each). Total cost involved roughly $170. Took 4 hours to do w/o a chop saw though.
Old Nov 10, 2004 | 04:57 AM
cleggboy's Avatar
get rid of the bottleneck
Old Nov 10, 2004 | 05:27 AM
Casey's Avatar
Default Re: (cleggboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleggboy &raquo;</TD></TR><TR><TD CLASS="quote">get rid of the bottleneck</TD></TR></TABLE>
read it makes stupid people smarter
Old Nov 10, 2004 | 06:01 AM
egizzle8
Guest
Posts: n/a
Default Re: (Casey)
what are you gonna do if you want to put a new muffler on? They sell just mandrel bent midsections in summit for like 120 bucks, and the muffler you can get on ebay for like 40 bucks. Either way good job on the fab work since you made it yourself.
Old Nov 10, 2004 | 06:05 AM
xci_ed6's Avatar
Default Re: (egizzle6)
I have not seen pre bent 3" midsections, and why would i want to put on another muffler?
egizzle8
Guest
Posts: n/a
Sorry I'm retarded and went back and noticed that it's 3''. The summit is like 2 3/8".
Old Nov 10, 2004 | 06:53 AM
phatrick2332's Avatar
Have you tried to install it in the car? I did the exact same thing on my turbo hatch, minus the fart can, and it was a bitch to get on the car in that big one piece. Mine was just straight 3" all the way from turbo out and i had to put the rear section through the LCA and then rotate the exhaust up into place, which means the car had to be jacked up about 2 feet just to do so.
Hope you have better luck than me, it looks nice.
Old Nov 10, 2004 | 07:12 AM
xci_ed6's Avatar
Default Re: (phatrick2332)
yeah, it fits real good, most of the welding was done on the car. I pulled it off to weld the top and paint it. I couldnt get any good pics of it on the car because my shop is too dark for my digi cam.
to put it on I just drop the LCA, it is only two bolts (that are easier to reach then b-pipe to muffler flange bolts anyway).
-Dustin
Old Nov 10, 2004 | 06:52 PM
sirb18's Avatar
nice paint job big for a DIY'er
Old Nov 10, 2004 | 07:04 PM
Bailhatch's Avatar
Default Re: (sirb18)
how did you use 2 spools to make that? were they 1/4lb ones or something? I can build like 2 whole turbo kits, including manifolds, charge pipes, DP, exhaust & brackets with one spool.
it looks pretty decent, i'm sure it flows just as well as any premade one
Old Nov 10, 2004 | 08:35 PM
xci_ed6's Avatar
Default Re: (Bailhatch)
1lb spools of .30 flux core
maybe i just use alot? I'm used to the like 20lb spools in the welder i had access to before, maybe i'm just not very efficient.
EKcivicDX
Jul 5, 2008 10:57 AM
13sechatch
Welding / Fabrication
27
Mar 29, 2008 02:32 AM
sauceja
40
Mar 12, 2007 09:46 AM
Dan-Dillinger
Jul 26, 2005 05:01 PM
dieselstation
Sep 29, 2002 04:05 PM
