Power Window fix??
Old Nov 8, 2004 | 05:29 PM
gaccord00's Avatar
Default Power Window fix??
Hey guys,
I own a 2000 accord, and out of nowhere all 4 of my power wins stopped working. I checkd the main window motor fuse under the hood, but it looks fine, and even replaced it with another one but still nothin. I also checked on the individual fuses in the inner door panel box, but they look fine also.
I called honda and of course they say "nah its never JUST a fuse, bring it in and we'll look at it for $100" well then WTF are fuses for??!!!
Anyone that can lend some knowledge or tips to try would be much appreciated.
Thanks!!
Jackie
Old Nov 8, 2004 | 05:35 PM
fw190bvi's Avatar
Default Re: Power Window fix?? (gaccord00)
check do the windows only not work from the drivers control panel, or from all switches?
Old Nov 8, 2004 | 05:52 PM
gaccord00's Avatar
Default Re: Power Window fix?? (fw190bvi)
From all switches.
Old Nov 8, 2004 | 06:09 PM
cmrvi1's Avatar
They're right. Fuses hardly ever give problems on the newer model power windows. The power windows in your car are controlled by the multiplex unit. These are three modules that control various electrical components in your car. The test procedure for the multiplex is too involved for me to try and explain it to you. The one thing you can check is the power window relay. It is located in the passanger side fuse box. It is on the back side of the fuse box. You'll have to access it from under the dash. You might need to remove that glove box to see it. If it is ok, then a trip to the dealership will be inevitable.
One more thing, try turning on the windshield wipers. These are controlled by the multiplex as well. It might be stuck in the sleep mode and has to be waked up ( NO KIDDING).
Old Nov 8, 2004 | 06:16 PM
gaccord00's Avatar
Default Re: Power Window fix?? (cmrvi1)
Thanks for the response. Yep I actually have used my wipers since the windows stopped working, and it didnt seem to make a difference. bummer, that sounded like a good idea! Well since you guys seem to have your shat together about all this, what would be a "worth it price" to pay the dealership for whatever replacement part they say I need? Meaning, how much money cud I possibly save by not buying their part and looking on ebay etc... and wud it be worth the effort??
Thanks again!!
jax
Old Nov 8, 2004 | 06:23 PM
cmrvi1's Avatar
As I mentioned before, the multiplex system is very complicated, and it can get expensive in a hurry if you start throwing parts at it and they don't fix the problem.
But if you want a starting point, start with the driver's side master switch. It contains the multiplex module that controls the windows.
Old Nov 8, 2004 | 06:33 PM
gaccord00's Avatar
Thanks. so what price range should I expect for the driver's side master switch?
Old Nov 8, 2004 | 08:42 PM
hawkmgc's Avatar
They range from $10 to RIPOFF
Personally I would take the switch apart and clean it. Most of the issues is that there is too much dirt between the connections. That ia normally what makes them stop unless you fry the board out.
Old Nov 9, 2004 | 05:43 AM
gaccord00's Avatar
Default Re: Power Window fix?? (hawkmgc)
Thanks. So is this the driver's side master switch that youre referring to? Is it fairly easy to remove and clean - w/out much experience? The car is already at honda, so if they tell me the board is fryed, what would be a fair price vs a ripoff price? BTW, my moonroof is also not working.
Thanks again.
Old Nov 9, 2004 | 10:02 AM
PrettyLude's Avatar
that main window switch is expensive, try to find one at the junk yard
Old Nov 9, 2004 | 01:36 PM
hawkmgc's Avatar
I don't have one for that new of an Accord.
So you will have to hunt at your local bone yards. A good used price seeing as its that new is about $35. New I don't even want to look.
Good luck
Old Nov 9, 2004 | 04:29 PM
Suke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaccord00 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
I called honda and of course they say "nah its never JUST a fuse, bring it in and we'll look at it for $100" well then WTF are fuses for??!!! </TD></TR></TABLE>
From someone who knows some about electronics,
Fuses are used to prevent too much current from flowing through a circuit. When too much current flows it burns the filament creating an open circuit and therefore protecting the electronics from getting too much current.
Therefore.. if your fuse has burned out it could just be a fluke, but it is most likely due to some other problem which caused it to burn out. So if you replace the fuse.. it's likely it will just burn out again.
Old Nov 9, 2004 | 08:00 PM
hawkmgc's Avatar
Default Re: Power Window fix?? (Suke)
But fuses fail. That is why circuit breakers are better. When those fail you have nothing. Instead of fried out fuses with burnt wires.
LOL
matt846
Jan 27, 2020 04:13 PM
sam234
Aug 11, 2012 09:10 AM
toronto_thunder
May 2, 2008 06:36 AM
int3gra07
Sep 15, 2005 05:52 AM
WhiteVX
Jan 7, 2005 03:07 PM
