Weird noise (while moving; not suspension/brake related)
The car is a 91 DA and I am getting this strange noise from what sounds like the middle to passenger side of the engine bay. I can best describe it as a "squeeky vibration." It only happens when I am in motion, and is not rpm dependant. It's rhythmatic....goes for about a 2 second burst, then is silent for about a second, then repeats. I can press in the clutch while coasting, and it still makes the noise. I can also hear a faint hiss while moving, and when I stop completely, the hissing goes away (as it goes away it sounds like an intake after you shut the car off).
I did notice that my power steering was just below the minimum line, so I topped it off, then drove 30 miles home. The sounds are still there.
It seems like whatever it is, it must be linked to the VSS somehow. I don't see how else it would only start when the car is in motion, even when coasting. Could it be the power steering just having air in it? This one is really confusing me, and I have never heard a noise like it.
Was the power steering foamy? If not, it wouldn't be that. Besides, the pump & reservoir are over on the left. You have to be pretty far below the min line before it sucks air & gets foamy.
Does it change if you apply the brakes softly? Apply them hard? A wheel bearing shouldn't change, but brake pads/calipers should change.
AnAccordIsForever
May 16, 2016 10:35 AM
Briman2021
Jul 31, 2002 11:54 AM
