Cooling boosted lude
I know boosting h22s or pretty much any motor its going to run hot. My egt isnt installed yet so I cant really get accurate readings. Anyways I was driving it not even pushing it hard and 3 bars on the heat thermometer. Oil is fine, intercooled sc61 turbo, just replaced radiator (oem).
What else could I do to make this run a little cooler and safer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jon9116 »</TD></TR><TR><TD CLASS="quote">I know boosting h22s or pretty much any motor its going to run hot. My egt isnt installed yet so I cant really get accurate readings. Anyways I was driving it not even pushing it hard and 3 bars on the heat thermometer. Oil is fine, intercooled sc61 turbo, just replaced radiator (oem).
What else could I do to make this run a little cooler and safer</TD></TR></TABLE>
What about using a radiator that is designed with a transmission cooler built in? I recently purchased one and was thinking about hooking up some lines to the oil system...
Anyone have any ideas if this would work? Where can you tap off of?
Mugen_DC2R
Mar 14, 2006 12:42 AM
markysparky
17
Nov 2, 2005 05:54 PM
