Project 99% complete (EG B20vtec)
My summer toy is almost done. Now its off to the dyno for tuning!!
Block-B20B decked 8 thou & bored to 84.5mm after installing an Arizona Race & Machine Block Guard.
GSR Main Bearing Girdle
GSR Oil Pan/Windage tray & oil pick-up (fitted with Oil Temp pick-up)
Type r liquid/liquid oil cooler
Type r water pump
Integra full size dual core radiator
Crower 63-401 Cams
Type R Fuel Pump
Mitsubishi Eclipse 450cc “blacktop” injectors
Oil Pump passages relieved/polished – pressure spring shimmed
New ACL Bearings
Eagle forged 4340 steel “H” beam rods
ARP 2000 Rod Bolts
Endyn Roller Wave Mid-Comp forged Aluminum pistons (Wiseco Hi Silicon blanks)-Domes glass bead peened
Crank/rods/pistons balanced
ARP Head Studs
GSR VTEC Head – CCs polished and relieved, fresh 3 angle valve grind, modified for LS-VTEC Oil delivery, shaved 5 thou for cleanup only.
Skunk II intake manifold
DC Sports one piece 4 into 1 ceramic headers - 2.5 inch collector, EGT pickup
Custom 2.5 inch end-to-end mandrel bent exhaust with Magna-Flow hi flow Cat, Thrush 28 inch Magnum Glass-Pack Resonator, and Magna-Flow hi performance straight through Muffler.
Clutch – Type r flywheel, ACT Street/Strip clutch disk, Exedy pressure plate
Endyn/Moroso Remote Crankcase Breather Tank kit
Chipped P28 ECU
RUNNING GEAR REPLACEMENT
5 Bolt Conversion
Full front and Rear Type R suspension
Type R 11” front Discs/calipers
Type R 10” rear discs/calipers
Russell Braided stainless flex lines
15/16” Master Cylinder
Disc/Disc proportioning valve
Tein HA coilovers (spring rates - Fr 12k/mm, Rr 10k/mm)
Energy Suspension Urethane Bushings - front
Type R 15x7 wheels
Falken Azenis 205/50/R15 tires
OTHER
B16 Hydro Transmission with LS 5th gear
Type R Helical LSD
Hawker Odyssey PC625 Drycell Battery
Integra front seats
JDM headlights and corners
JDM Instrument Cluster plus:
Auto-Meter Pro-Comp Ultralite Gauges - Oil Temp/Oil Press/EGT/Voltage
Modified by b20mike at 2:00 AM 11/15/2004
Type r water pump
Crower 63-401 Cams
Type R Fuel Pump
New ACL Bearings
ARP 2000 Rod Bolts
ARP Head Studs
Chipped P28 ECU
5 Bolt Conversion
Type R 15x7 wheels
OTHER
Type R Helical LSD
Integra front seats
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20mike »</TD></TR><TR><TD CLASS="quote">Now its off to the dyno for tuning!!</TD></TR></TABLE>
Nice outcome, engine bay looks really clean. Keep us posted on th dyno #'s.
Nice body kit *** when ya gonna get it painted
/sarcasm
J/P man, looks real nice. Cleaner than I could ever keep my car.
for that beast.
(seriously though, get the bumper painted
/sarcasmJ/P man, looks real nice. Cleaner than I could ever keep my car.
for that beast.(seriously though, get the bumper painted
That's sick. There was a kid at the local track with a semi-build B20/VTEC running 12.5-12.6 all-motor all night and 11.8-11.9 with Nitrous. Fell in love with B20/VTEC.
looks like a camber problem right rear
