ECU help
Old Nov 8, 2004 | 02:12 PM
CRX_Type_R's Avatar
Default ECU help
I have a 91 CRX Si with a D16Z6 motor and was wondering if the P28 will plug into the ECU harness perfectly or do I need a seperate harness. I am currently running with a stock CRX Si ECU.
Old Nov 8, 2004 | 02:41 PM
Rywire's Avatar
Default Re: ECU help (CRX_Type_R)
you need to be obd1, and you need the obd1 ecu plugs.... you can repin the ecu pins in the new (obd1) locations or purchase a obd0-1 jumper.
Just do a search for obd0-1 swap.
Ryan
HuntsAlone
60
Jun 18, 2015 04:26 PM
NickGREPSMN
May 2, 2013 04:08 PM
mikelaw420
Jul 29, 2010 08:45 PM
josh_db1
May 11, 2010 08:35 AM
