radiator for crx
It's half size, but it won't bolt in... the radiator is aobut 2-3" taller than factory, so it has to be tilted back or custom mounted ot the crossmember, OR buy an aftermarket x-member like the Z-10, or others...
HTH
HTH
Yeah... it's taller by quite a bit.. It might be more trouble than it worth, but I have one in my H/B.
What I did was moved my battery to the trunk, tilted the rad back and made a simple little bracket that hooks onto the top of the rad.. Oh.. another thing is you'll have to get another fan cause the original one is too wide. The one I'm using is off a Dodge Caravan and it works great... Yeah.. you'll have to make little brackets to bolt the fan to the rad..
The lower rad supports... I had to get another set off some car... Cause the stock ones is too far apart. The rad has to sit a little further up or else the lower rad hose won't clear the front crossmember. Try not to get an auto one.. cause the fittings kind of get in the way.
If you're running a DOHC motor.. It'll be a little better and easier to make the upper rad hose fit... If not.. The SOHC will be very hard and tight to make it fit.. it's almost forced on.
I'll see if I have time to take a pic and post it up. Then you'll be able to see how it looks.
After all that and if you're wondering why I would be crazy enough to do all that modifying... Just think... BOOST.
When you are ready to get your replacement radiator. Go to http://www.radiator.com and use this coupon# AC116 for $20.00 off your purchase.
crxjake
Dec 2, 2004 10:37 AM
jdmcrx1
Feb 23, 2003 09:20 AM
