90 crx drx e-brake adjustment
Old Nov 8, 2004 | 01:04 PM
1badrex's Avatar
Default 90 crx drx e-brake adjustment
hey guys ive got a 90 dx rex, the e-brake really sucks on it. i can pull it up all the way and it still moves a lil bit, how can i adjust it? my gurl has a 90si hatch that the ebrake is reallty tight u pull like a quarter of the way up maybe less, can someone please tell me how to do this. oh and if anyone has an si harness for sale please let me know how much. thanks
Old Nov 8, 2004 | 01:18 PM
RCautoworks's Avatar
Default Re: 90 crx drx e-brake adjustment (1badrex)
Look at the e brake, then look back. See the little cover, take it off and tighten the nut. You might need to replace the back brakes soon.
Old Nov 8, 2004 | 01:24 PM
92integra_gs's Avatar
yea just follow the helms manual on top... clockwise to tighten that ebrake up
Old Nov 8, 2004 | 01:51 PM
drdisco69's Avatar
Default Re: (92integra_gs)
The right way is to adjust it at the rear drum. Remove the rear drum and you'll see a little wheel with teeth on it in the middle of everything. Give it a few clicks to tighten things up.
Old Nov 8, 2004 | 01:54 PM
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">The right way is to adjust it at the rear drum. Remove the rear drum and you'll see a little wheel with teeth on it in the middle of everything. Give it a few clicks to tighten things up.</TD></TR></TABLE>
No, thats the right way to adjust the rear brakes.
Old Nov 8, 2004 | 01:59 PM
drdisco69's Avatar
Default Re: (90blackcrx)
Oh, we're too tight. Didn't see that. Well either way, too tight at the handle usually means too tight at the shoes in the rear. I would see how tight it is back there, dragging shoes on the drums is never good.
Old Nov 8, 2004 | 02:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Oh, we're too tight. Didn't see that. Well either way, too tight at the handle usually means too tight at the shoes in the rear. I would see how tight it is back there, dragging shoes on the drums is never good.</TD></TR></TABLE>
Yeah, there are actually 2 problems.
Anyways if you can pull the parking brake all the way up then more then likely your rear brakes need to be changed.
But if its to tight, either someone tighten the parking brake to much or the rear pads are infact dragging.
nicknack25
Feb 19, 2014 07:23 PM
crxaddikt
Dec 1, 2012 03:28 PM
IntegralGSR
Oct 25, 2007 08:37 PM
DarkSol97
Dec 23, 2006 11:24 AM
ekoms31
Oct 21, 2004 06:07 PM
