what are some rims that fit 95 prelude sr-v\?
im asking this cuz i am planning on buying a set of winter tires, and i want to buy cheap rims that would fit my car, so any help?
4th Generation (1992-1996)
205/55/15 - Stock Size, Recommended 15” Size Tire
205/50/15 - Better Acceleration, Overall Diameter is Smaller
215/50/15 - Larger Contact Patch, Better Acceleration, Overall Diameter is Smaller
225/45/15 - Even Larger Contact Patch, Minimum of 7" wide wheel is recommended, Overall Diameter is Smaller
225/50/15 - Even Larger Contact Patch, Minimum of 7" wide wheel is Recommended
205/50/16 - Recommended 16” Size Tire
215/45/16 - Larger Contact Patch
215/50/16 - Larger Contact Patch, Overall Diameter is Larger
225/45/16 - Even Larger Contact Patch, Minimum of 7" wide wheel is Recommended
205/40/17 - Overall Diameter is Smaller, Not Recommended w/ 7.5" wide or larger wheel
215/40/17 - Larger Contact Patch, Recommended 17” Size Tire
215/45/17 - Larger Contact Patch, Overall Diameter is Larger
225/40/17 - Even Larger Contact Patch, Very Limited Selection of Brands
215/35/18 - Larger Contact Patch, Small Profile means Less Protection for Wheels
215/40/18 - Larger Contact Patch, Overall Diameter is Larger
225/35/18 - Even Larger Contact Patch, Recommended tire size for 18x7.5" with at least a +48mm offset
225/40/18 - Even Larger Contact Patch, Overall Diameter is Larger, Not Recommended if car is Lowered
