NO A/C and I just got it fixed!
Ok i just replace my a/c compressor, it spins, but there is no cold air coming out of it. Like there is no power going to the thing at all. Why isn't the damn thing working? Is there a way to fix it? Could it be the wire harness was fried during the previos compressor's lock up? Someone help me...
Check refrigerant level. If that's good, then remove the harness that plugs into the compressor/clutch relay and jump the positive terminals, I think it's the white and blk/yellow wires. If the compressor engages, then its porbably the relay; if not, then there's probably no pwer coming from the fuse box to the relay (the white wire).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonathanRuiz »</TD></TR><TR><TD CLASS="quote">Ok i just replace my a/c compressor, it spins, but there is no cold air coming out of it.</TD></TR></TABLE>
When you say it spins, what spins???Just the a/c pulley? Or does the clutch spin as well??
jdm_rb20
19
Apr 26, 2013 07:52 PM
superfuji57
Jul 14, 2007 05:38 PM
DRFlickner
14
Sep 24, 2003 07:09 PM
